Help Removing Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By jbfan
Old 10-29-2016, 07:44 PM   #1
Rewards Points: 6
Help removing junction box
I am trying to replace an existing light fixture with recessed lighting and am having trouble removing this octagonal metal junction box (see photo). I have already removed a screw and the locknut that was holding the wires in place. It moves a bit when I pull it, but I think there is also something metal on 2 sides that is currently holding it in place? I'm not sure if this is part of the junction box or part of the metal studs in the house??
I want to avoid cutting a hole in the ceiling as the recessed lighting would fit well in the existing hole. There is no attic access (the junction box is on the 2nd floor of a 3 storey townhouse). Any advice on how to remove the box?
Thank you in advance.
drekkan is offline   Reply With Quote
Old 10-29-2016, 07:50 PM   #2
Rewards Points: 6
Re: Help removing junction box
Apologies for the double post - forgot the photo: http://imgur.com/e7hCzSN
Old 10-29-2016, 08:03 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,442
Hard for me to tell, but it looks like 2 nails in the center of the box.
Rafter above the box?
J. V. and Msradell like this.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 10-29-2016, 08:04 PM   #4
Rewards Points: 312
Trying to put a recessing light in place of an existing octagon box is a risky thing to try. Success rate isn't too good. Many times, we will cut short pieces of steel stud, hat track, or C-channel to brace an octagon box in the ceiling for the future surface light.
Power- is offline   Reply With Quote
Old 10-29-2016, 10:43 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 1,288
Or a side bracket.
lenaitch is offline   Reply With Quote
Old 10-30-2016, 06:48 AM   #6
Master Electrician
Rewards Points: 5,264
The box probably looks like this with nails or screws in the bracket. Slide a jab saw or sawsall between the rafter and the bracket to cut off the fasteners. Help removing junction box-img_0268.jpg
brric is offline   Reply With Quote
Old 10-30-2016, 06:56 AM   #7
Master Electrician
Or push the box into the opening to loosen the fastenters and use a pry bar between the joist and the bracket.
Old 10-30-2016, 08:38 AM   #8
Rewards Points: 18
A sawzall with a flexible metal blade will do the trick. Try to run it rubbing against the joist so you are cutting the nails or screws holding the box to the joist, rather than cutting the metal wings of the box. The sawzall will cut either, but the fasteners are yhe easiest to cut.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 10-30-2016, 01:25 PM   #9
J. V.'s Avatar
Rewards Points: 362
I see two nails also. Looks like the box is nailed to the rafter or 2x4 installed to support the box.
Old 10-30-2016, 02:31 PM   #10
Rewards Points: 312
If your referring to the "nails" just north and south (figuratively speaking) of the center 1/2 KO.........I think those are factory punchouts in the box that were not removed. Whereas, the other remaining four (4) have been removed.
Installing Light on Round Junction Service Box MegR Electrical 7 07-07-2013 08:31 PM
Junction Box location marly Electrical 1 08-24-2012 11:00 AM
Can ceiling light box serve as a junction box as well? dalepres Electrical 4 05-12-2012 10:09 PM
Temperature in junction box buried under R49 insulation (heat detectors/smoke alarm) darlingm Electrical 2 01-16-2012 03:55 PM
What can I use as a junction box? emory Electrical 3 10-15-2011 09:36 AM
