HELP - Question On Amperage Capacity! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 10:33 AM   #1
HELP - Question on amperage capacity!
I have a 220V/200A/Single phase main panel in my house and I want to run a sub panel over to my workshop. I have to run about 60' to the new panel. I am planning on running 6/3 SOW 90C stranded copper wire, but I have found conflicting info on the maximum amperage capacity of this wire... I have seen 60 and 55A. I would like to run a 220V 60A sub panel, but I am not sure if I am going to be limited to a 50A. Does anyone know for sure?
I am going to be running a welder with a 38A max input as well as lights, etc...
Jiddru is offline   Reply With Quote
Old 12-19-2009, 11:22 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,998
Type SOW is not suitable for connecting a sub panel. It is basically large extension cord. Plus it doesn't have enough conductors. It only has three conductors. You needs four for a sub panel. SO cord is labled different than NM-B cable.
6/3 NM is suitable for a 60 amp sub panel.
Old 12-19-2009, 11:57 AM   #3
Rewards Points: 1,016
This is attached area or detached building with the workshop where the subpanel is going? Sounds like attached, but want to be sure as if so things are a bit different.
Old 12-19-2009, 12:33 PM   #4
Attached... it is just going from one side of the basement to the other. The only reason i am using the SOW wire is because I have an extra 100' of it... I know it is a bit of overkill, but I really don't have another use for it.
Old 12-19-2009, 12:45 PM   #5
You do need 4 wires, so will be unable to use the SOW wire
Old 12-19-2009, 12:58 PM   #6
Licensed Pro
As has been pointed out, SOW canNOT be used in this application. You need 6/3NM. It is not overkill, it is an improper use of the material.
question about a generator amperage pnutzhome Electrical 4 11-10-2009 08:09 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Can I double wire and increase amperage capacity? YerDugliness Electrical 24 08-22-2008 05:45 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
