Help With Power Requiremwnts For 3 Phase Sander - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2016, 11:37 AM   #1
Rewards Points: 8
Help with Power Requiremwnts for 3 Phase Sander
Hi,
My son has bought a Large 3 Phase drum sander for his shop, I'm 99% sure his current transformer is to small for the sander. Hi current transformer reads 15 KVA, he wants to make sure to get the right size before having everything hooked up.
The sander List the following
Motor#/ H.P. /Amps /Voltage
1 - 25 - 60.1 - 230
2 - 20 - 48.1 - 230
3 - 2 - 3.8 - 230
4 -1/4 -- 1.2 - 230
What is the total KVA for this setup?
JoeEngler is offline   Reply With Quote
Old 11-26-2016, 12:31 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,680
Re: Help with Power Requiremwnts for 3 Phase Sander
That is almost 50 amps at 230 volts.
50 amp at 230 volts is 11.8 KVA.
Old 11-26-2016, 03:23 PM   #3
Rewards Points: 8
Thank You sounds like since nothing else is using the current 14 KVA transformer then he is good to go.
Old 11-26-2016, 05:10 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 3,666
Doesn't that add up to 113.2A based on the information he gave? That would be 41kVA.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 11-26-2016, 06:02 PM   #5
Super Moderator
joed's Avatar
Oh dang you are correct. I added the HP not the amps.
Old 11-26-2016, 06:32 PM   #6
Civil Engineer
Rewards Points: 5,246
A few details may be important. Do all the motors run simultaneously? Do they all start up simultaneously? Start up current on a motor can be substantially higher than running load current, and the transformer presumably needs to supply the start up current. There may be further information on the nameplate about startup current versus full load current.
Old 11-26-2016, 11:18 PM   #7
Disrespectful to dirt
Fishbulb28's Avatar
Rewards Points: 2,148
113.2 Amps of 3 phase at 230 volts is 45.1 kVA. To put that in perspective, the standard 200 Amp split phase service for an entire home is 48 kVA.
Is there no way to reconfigure the machine for 480V? It would save you a lot of money on equipment and materials assuming that's what the 15 kVA transformer is stepping down from.
Fishbulb28 is offline   Reply With Quote
Old 11-27-2016, 09:07 AM   #8
Rewards Points: 8
That is a good idea, I will take a run by his shop tomorrow and get some good pictures of the everything.
No, poco 240vac is single phase. concrete_joe Electrical 323 04-14-2016 07:16 PM
U.S. split phase power & transformer question nin304 Electrical 22 05-06-2014 10:00 PM
hELP! Amperage needed for 220V motors 1488rob Electrical 36 01-28-2014 04:44 PM
3 phase power help chadcooper55 Electrical 10 09-19-2012 09:24 PM
3 Phase Power regularguy Electrical 10 04-17-2011 12:26 PM
