Help (JV, That Means You!) On 220 Line Conversion - Electrical - DIY Chatroom Home Improvement Forum
Old 10-16-2009, 01:19 PM   #1
Help (JV, that means you!) on 220 line conversion
Okay, so I am dissecting the wiring ($#@^#!) on this home and have found that the builder spliced into a 220v dryer line, to run power across the garage ceiling and through the garage wall, capping the wires at an external box. I would LOVE to use this box to source the power at 110 for two outside (in the middle of the garden) outlets I want to install. Is there any special way that I can use this 220 line and decrease it to 110?
dpcowboy is offline   Reply With Quote
Old 10-16-2009, 02:53 PM   #2
I have yet see a setup as you describe. It's a dedicated service for a dryer and should remain such (probably a 30a line). The only way you could safely use the line is to come off it with a subpanel with breakers or fuses suited to the load you indicated -- if the line has a Neutral along with it (i.e., 120v on either side of neutral). I don't think that's code and I would not do it that way.
oilseal is offline   Reply With Quote
Old 10-16-2009, 03:33 PM   #3
Electrical Contractor
kbsparky's Avatar
You have stumbled across a major violation, and you want to continue to use and/or expand it?
How about removing the offending splice, and then run a new circuit if you want a new outside outlet?
-KB
Old 10-16-2009, 03:48 PM   #4
Stove circuits are spliced to serve cooktops & ovens
I understand that a circuit for a dryer could also be spliced
A 2nd dryer, another outlet - maybe to connect an RV
220.54 Calculated load for dryers shall be 5000w or actual nameplate whichever is larger
But I don't know of any way to take that & split it
Other then a small sub - which I'm not sure would be to code
Are there 3 wires or 4 wires?
Do you have an electric dryer?
Old 10-17-2009, 08:09 AM   #5
Rewards Points: 3,000
The "240 volt line" must have a white conductor in order to be converted outright to 120 volt usage. Any 120 volt usage relying on the ground for return current must be discontinued.
In order to have ordinary receptacles or lights connected to it, either a subpanel must be used or the entire line breakered at no more than 20 amps.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 10-17-2009, 10:53 AM   #6
No, I don't want to risk ANYTHING here. I would always rather redo the work and do it right. The builder of this home built several in this area and was/is a County Building Inspector/Supervisor who got the "nod-nod, wink-wink" from his fellow inspectors when building these spec homes. The 220 electrical dryer line was spliced and wire was run from the splice over 50 feet and then terminated with caps outside the garage. My question is whether I can adapt this 220v wire (safely) to run power out to a garden area (another 100 feet) where I want to install two outdoor receptacles. Seems like my best practice would be to correct the dryer line splice, leave that 220v line to itself, and hook up new power (110) through the circuit breaker...does this seem right? Or can I somehow convert that 220v wire run and splice it in a way to use 110? (again, safely!)
Old 10-17-2009, 10:55 AM   #7
How many wires are in the 240v run ?
Old 10-17-2009, 11:00 AM   #8
Scuba Dave,
Yes, there is a dryer...and it is the dryer 220v line that is spliced....actually, there are 7 wires exiting the garage terminus and going into an electrical conduit below the ground...(2 black, 2 red, orange, green, and white!). Any advice?
Old 10-17-2009, 11:12 AM   #9
If you can find out what he did & what he wired it for that would be #1
Since you have a dryer I'd leave that existing wire alone
I'd leave the existing garage connection, I haven't found anything in the code that prohibits splicing.
So I'd run new wire for 2 outside outlets
I ran 2 conduits - (1) 1/2" & the other 3/4" out to my garden for my Christmas display
What power draw is going to be on the outside outlets?
You go into many home garage workshops & there are multipe 240v outlets all running off the same circuit to power different tools
The idea being that the homeowner will not be using multiple tools at once & surpass the breaker/wire capacity
With that many wires you could possibly drop a small sub with 2 breakers & run 2 circuits
But I wouldn't do it unless I knew what all the wires were connected to & why
Old 10-17-2009, 12:16 PM   #10
J. V.'s Avatar
Rewards Points: 348
Dave, you are correct that splices and taps are not always a violation. Including this one. As long as the splice was made in an appropriate enclosure (box) and the wire is the same size, there is nothing wrong with it.
OP. Leave the 220 volt circuit as is. You may find a use for that box outside one day.
Run a new cable for the 120 volt circuits you require.
If it worked before you worked on it. You did something wrong.
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 07:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
GFI will not reset will line is hot soccerdude Electrical 15 09-07-2008 01:11 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
