Help...electrical Not My Thing. - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2016, 01:25 PM   #1
Rewards Points: 2
Unhappy
Help...electrical not my thing.
I have a lead wire that is four wire coming from a seperate braker off of the main box......it has a Red wire, black wire, white wire and a green wire.
My new tidal wave pump has a rear plate that comes off and only needs three wires (white, black and yellow to make a switch on the back panel run the 2 phases needed to run the high and low side of the pump.
I already have a toggle switch built into the deck so I need to know how to lose the pre wired set up that the pump has and replace it with the 4 wire set up that my lead provides. which will handle the toggling between pump speeds;
BAsiclally where does the red wire fit into the picture?
Confused yet?
Gerrel is offline   Reply With Quote
Old 04-30-2016, 02:38 PM   #2
Oso954's Avatar
Rewards Points: 1,660
Re: Help...electrical not my thing.
You need to provide the pump model number and more info on the 4 wire circuit to get a specific answer. Can you take voltage readings ? White to black, white to red, and red to black.
However, I am guessing that your this may be a replacement pool pump. If so, you may have a 240V circuit. If your replacement pump is the one I think it is, it is 120V.
Oso954 is offline   Reply With Quote
Tags
3 wire to 4 wire setup
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 03:19 PM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
