Help Determining Proper Junction Box Size - Electrical - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By CodeMatters
  • 1 Post By brric
  • 1 Post By Jim Port
Old 03-11-2019, 01:13 PM   #1
Rewards Points: 14
I am doing some updating in our kitchen and wanted to make sure my box is large enough to contain all the splices, etc. and am having a hard time calculating it.
I plan to use a 3-gang old work box with these specs: 5.72-Inch Length by 2.79-Inch Width by 3.69-Inch Depth. I believe it's 55 cubic inches.
I plan to take the incoming 12/2 line and pigtail off of it to
1 GFCI outlet (end run)
2 separate switches
1 hardwired undercabinet light
(obviously the 12/2 running from the switches to the lights)
The lights were previously wired with a switch loop. I didn't want to go that route, primarily because I don't have any 12/3 and wanted to stay up to code having a neutral available in all switch locations.
Any help would be appreciated and sorry if this is confusing.
gilliger is offline   Reply With Quote
Old 03-11-2019, 01:46 PM   #2
hkstroud's Avatar
Rewards Points: 5,572
Re: Help Determining Proper Junction Box Size
Google NEC 370-16 (a)
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 03-11-2019, 02:05 PM   #3
Rewards Points: 470
I would never mix power and lighting on the same circuit. You are only asking to be in the dark if you happen to kick a breaker. I would also use one of the device boxes as my junction box. I would never have a junction box any where in the circuit other than a device box. I would gang 2 or maybe three boxes together to ensure I have plenty of room.
But I like making thing easy for myself when it comes to electrical hardware and circuits.
Andrew
Handy Andy In Mt Airy NC
HandyAndyInNC is offline   Reply With Quote
Old 03-11-2019, 03:30 PM   #4
CodeMatters's Avatar
Rewards Points: 6,196
I wouldn't waste time calculating. I'd use a plastic box and forget about it.
It'll easily be big enough for your needs.
Note: I'm assuming that plastic boxes are larger than metal where you are,
same as they are here where I am.
Edit: another note - plastic boxes often have "wings/tabs" on the end of the
box (away from the stud) that make their mounting simpler since you don't
have to make/add anything to the end of the box to prevent it from pulling
forward when the devices are screwed in.
CodeMatters is online now   Reply With Quote
Old 03-11-2019, 03:41 PM   #5
Mixed circuits in residential is something about 1 in a hundred people care about........I'm not one of 'em.
jbfan and brric like this.
Old 03-11-2019, 04:11 PM   #6
Master Electrician
Rewards Points: 4,920
If the GFCI is part of a small appliance branch circuit, it cannot be part of a lighting circuit.
jbfan likes this.
brric is offline   Reply With Quote
Old 03-11-2019, 05:48 PM   #7
Licensed electrician
Rewards Points: 3,592
The plastic.box will be stamped with the number of conductors and capacity.The
As above the small appliance circuits should not have lighting on them.
Domo likes this.
Proper junction box for addition tonepaq Electrical 6 05-22-2017 07:37 AM
Proper Gas Line Size nateo Plumbing 8 11-26-2012 09:37 AM
Proper awg wire size to use? Suzuki91vx800 Electrical 36 06-23-2009 04:18 PM
Tankless water heater proper pipe size? gante Plumbing 5 04-06-2009 02:28 PM
Need help determining the size of an upstairs HVAC unit BigE516 HVAC 11 03-17-2009 03:25 PM
