DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Help Determining Proper Junction Box Size (https://www.diychatroom.com/f18/help-determining-proper-junction-box-size-655247/)
gilliger 03-11-2019 01:13 PM
I am doing some updating in our kitchen and wanted to make sure my box is large enough to contain all the splices, etc. and am having a hard time calculating it.
I plan to use a 3-gang old work box with these specs: 5.72-Inch Length by 2.79-Inch Width by 3.69-Inch Depth. I believe it's 55 cubic inches.
I plan to take the incoming 12/2 line and pigtail off of it to
1 GFCI outlet (end run)
2 separate switches
1 hardwired undercabinet light
(obviously the 12/2 running from the switches to the lights)
The lights were previously wired with a switch loop. I didn't want to go that route, primarily because I don't have any 12/3 and wanted to stay up to code having a neutral available in all switch locations.
Any help would be appreciated and sorry if this is confusing.
hkstroud 03-11-2019 01:46 PM
Re: Help Determining Proper Junction Box Size
Google NEC 370-16 (a)
HandyAndyInNC 03-11-2019 02:05 PM
I would never mix power and lighting on the same circuit. You are only asking to be in the dark if you happen to kick a breaker. I would also use one of the device boxes as my junction box. I would never have a junction box any where in the circuit other than a device box. I would gang 2 or maybe three boxes together to ensure I have plenty of room.
But I like making thing easy for myself when it comes to electrical hardware and circuits.
Andrew
Handy Andy In Mt Airy NC
CodeMatters 03-11-2019 03:30 PM
I wouldn't waste time calculating. I'd use a plastic box and forget about it.
It'll easily be big enough for your needs.
Note: I'm assuming that plastic boxes are larger than metal where you are,
same as they are here where I am.
Edit: another note - plastic boxes often have "wings/tabs" on the end of the
box (away from the stud) that make their mounting simpler since you don't
have to make/add anything to the end of the box to prevent it from pulling
forward when the devices are screwed in.
CodeMatters 03-11-2019 03:41 PM
Mixed circuits in residential is something about 1 in a hundred people care about........I'm not one of 'em.
brric 03-11-2019 04:11 PM
If the GFCI is part of a small appliance branch circuit, it cannot be part of a lighting circuit.
Jim Port 03-11-2019 05:48 PM
The plastic.box will be stamped with the number of conductors and capacity.The
As above the small appliance circuits should not have lighting on them.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
