Help Changing Fluorescent Lighting In Bathroom And Kitchen - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2009, 03:57 PM   #1
Question
Help changing fluorescent lighting in Bathroom and Kitchen
Hello All,
I am in need of some help here please. I have lights that look similar to this
[IMG]file:///C:/Users/P&J/AppData/Local/Temp/moz-screenshot-4.jpg[/IMG][IMG]file:///C:/Users/P&J/AppData/Local/Temp/moz-screenshot-5.jpg[/IMG]
What tools do I need to either install pot lights or track lighting in place of these ugly fluorescent lighting.
I understand how to remove them, but once I take the ballast down will I need to install new wiring or will I have to use new wiring from the junction box?
Any insight that anyone has is most greatly appreciated.
Thanks all!
boomsday is offline   Reply With Quote
Old 11-20-2009, 04:21 PM   #2
Licensed electrician
Rewards Points: 3,746
That looks like fluorescent strip lights above drop in panels. Those panels are not rigid enough to support recessed lights. Do you plan on taking down the drop ceiling?
New wiring will need to run between the fixtures as well as from the source to the first recessed.
Old 11-20-2009, 04:22 PM   #3
Illuminance
(lux)
resi. toilets, hallways, 80 to 100
School classrooms, Kitchen work areas, office lighting 300 to 500
To choose how many fixtures you need, you may want to get the fixture light levels from the manuf.
Nobody lists it even though it's the main reason you buy a light.
Old 11-20-2009, 04:54 PM   #4
Hello, thanks for the quick answers guys.
Yeah it is strip lights above the drop in panels and I plan on taking down those old wooden panels and replacing it all with drywall.
I know how to do the drywall install etc but am not sure about about the electric work that is necessary.
Old 11-20-2009, 05:55 PM   #5
You will need to install new wiring between the new recessed cans
You may be able to re-use the main power feed in the ceiling
All depends upon where everything is located now, where the new stuff will be going, any slack in the line & if you want an accessible junction box somewhere in the ceiling
Old 11-20-2009, 06:44 PM   #6
All the recessed I have seen for the last several years all required 90 degree rated insulation. If your non-metallic cable does not say NM-B, it is only 60 degree rated.
Old 11-20-2009, 06:47 PM   #7
Originally Posted by Yoyizit View Post
Illuminance
(lux)
All you need to do is read the IES files, some are right in the catalog. Not hard to get.
Old 11-20-2009, 07:22 PM   #8
These guys?
http://www.iesna.org/
Old 11-20-2009, 07:36 PM   #9
Very good point, I have some leftover 12-2 that is only rated NM
Bathroom exhaust vent in kitchen? dc4nomore HVAC 11 05-27-2009 12:06 AM
My bathroom and kitchen remodel vetting Project Showcase 17 04-25-2009 09:36 AM
DuPont Laminate in Bathroom and kitchen wedge22 Flooring 4 02-17-2009 01:33 PM
Venting up vs out for bathroom, kitchen pcampbell HVAC 12 11-15-2008 10:02 AM
kitchen wall and bathroom fans sharing duct amakarevic Building & Construction 5 06-11-2008 12:13 AM
