HELP! Bad Switch Or? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2016, 08:48 AM   #1
Rewards Points: 2
HELP! Bad switch or?
So - the kitchen ceiling light blew the other day. I'd turned it off then back on quickly because I'd forgotten something. I thought it was the bulb but replacements don't work.
Bathroom and microwave on same circuit and work fine, thought I don't know the path of the circuit. The other ceiling tight in kitchen also won't work. Both lights in one receptacle but separate switches (see attached photos)
I don't know if the switch on the right goes it will affect the other? The only thing I can think to do is change both. The one on left we haven't used in a long time anyway so I don't know if it's been bad, too, or..?
Gspeex is offline   Reply With Quote
Old 10-17-2016, 10:39 AM   #2
JUSTA MEMBER
Rewards Points: 4,446
Re: HELP! Bad switch or?
Those DECORA switches are usually resilient, but after a few years of age they can get brittle inside and break the little plastic tangs that operate them.
I have had them in my place for 35= years, and the only time that one quit was when I slapped it too hard.
Go buy two to replace them, replace the one that you use most often, to see if it repairs the system, and if this fixes all , return the one, or keep it stored as a spare. If it only fixes the one light, replace the second also.
If this don't fix anything, look for a broken wire, or maybe a tripped breaker, cycle the breaker off then on, sometimes they trip and it is not obvious to see.
ED
de-nagorg is online now   Reply With Quote
Old 10-17-2016, 01:34 PM   #3
Electrical Contractor
Rewards Points: 312
"...the kitchen ceiling light blew the other day..." = define your term "blew"? Blew the breaker?.....Blew the lamp?......What do you mean by "blew"?
"...I'd turned it off then back on quickly..." = "it" is what? Breaker? Wall switch?
"...Both lights in one receptacle but separate switches ..." = Both lights AND one receptacle? Your picture shows two switches....right-hand switch should do what?, and left-hand switch should do what?
The clarity will help for an electrician to assist you without us being there.
Power- is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Weird 3-way switch shenanigans going on. poiihy Electrical 11 09-12-2015 04:28 PM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
