HELP ASAP! 150V One Line And 80V Other! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-12-2010, 11:33 AM   #16
Mad Scientist
This looks like a textbook bad neutral. If the PoCo didn't actually find and fix it while they were out, keep calling them until they do. And if you have any electronics you're fond of, keep them unplugged until it's fixed. Under the right circumstances, the voltages can swing as far as 240 on one leg and zero on the other. That tends to let the smoke out of things.
McSteve is offline   Reply With Quote
Old 08-17-2010, 03:18 PM   #17
Turned out that the main wires coming in were loose on the ground and one of the others. >.<
We fixed it and pulled everything out of the panel and put it back in and copper coated the ends of wires.
wtfh4xx is offline   Reply With Quote
Old 08-17-2010, 07:21 PM   #18
Electrician
Proby's Avatar
You just found out today?
Why didn't PG&E find that out when they came out almost a week ago?
Either way, I'm glad it's fixed
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-17-2010, 08:50 PM   #19
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
I would immediately cut power to everything. Try to borrow a generator or ask a neibor to plug in their house to power the essentials like the fridge. This is very damaging especially to electronics. Even if everything seems to be working, something such as the fridge kicking in, or a sensor light going on due to a bird, can throw everything off balance.
Edit: nm, did not realize it was fixed
Old 08-17-2010, 10:54 PM   #20
" Euro " electrician
frenchelectrican's Avatar
That in load centre or outside like in meter socket or overhead conections ??
Merci.
Marc
Old 08-19-2010, 07:15 PM   #21
It was the three main wires coming from the pole that connect to the meter.
