Heater Contactor Location - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 09:40 PM   #1
Rewards Points: 113
heater contactor location
I plan to regualte my 220 volt, 23 amp shop heater with a thermostat. The line is 10 ga. with a 30 amp breaker. I plan on adding a 30 amp, 2 pole 24 volt coil contactor between the breaker and heater for the thermostat to contol. The transformer for the 24 volt thermostat will be rated at 20VA.
Question: Does the "code" allow me to put all connections ( incoming and outgoing 10 ga. wires, contactor, and 24 volt thermostat wires) inside a large junction box or must the contactor be inside the heater housing?
Thanks.
Captflx is offline   Reply With Quote
Old 02-28-2010, 08:52 AM   #2
Electrical Contractor
kbsparky's Avatar
The contactor and associated enclosure can be mounted anywhere between the source and the heater.
The 24 Volt wiring can enter the same enclosure, but those conductors' insulation should be rated for at least 240 Volts unless there is a solid separation barrier installed within the enclosure.
-KB
Old 02-28-2010, 11:18 AM   #3
Idiot Emeritus
Rewards Points: 80
It's pretty common to install the contactor and transformer in a J-box somewhere near the heater. Usually, right above the thermostat.
If there's a disconnect switch, it's best to install the J-box between the disconnect and the heater.
Rob
micromind is offline   Reply With Quote
Old 02-28-2010, 04:56 PM   #4
Rewards Points: 113
kbsparky----I don't understand the 24 volt insulation rated for 220 volts. The 24 volt wires going into the J-box to the contactor will be from the thermostat. Can you explain?
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
