Hardwiring Smokes - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2010, 09:00 AM   #1
Rewards Points: 93
Hardwiring Smokes
Hello, I am hardwiring smoke dectors throughout house. Ran the cables over the weekend. I am putting a junction box in attic (accessable) to tap off to get power. I ran 14/3 to each dector. The first one coming out of the junction box to the first dector, I ran 14/3 and then continued to run 14/3 to each one after, so each location has the two cables. The first one, coming out of the junction box, I was going to run 14/2 to power the first smoke and then run the 14/3 with the traveler between each one, but accidently didn't. For the first one can I just not connect the traveler (red) and wire nut it in the junction box and dector box or should I re-run a 14/2 to the first smoke? Should be easy to do because I can use the 14/3 as a pull. What is the correct thing to do?
bfan781 is offline   Reply With Quote
Old 03-15-2010, 09:04 AM   #2
Master Electrician
Rewards Points: 5,082
If I understand correctly you ran a 14-3 to the first smoke box as a power cable. That is ok just an extra wire. Just use the white and black and cap off the red.
brric is online now   Reply With Quote
Old 03-15-2010, 09:18 AM   #3
Rewards Points: 93
Exactly. I just wanted to back sure they wouldnt have a problem capping the red at each end. Meant to run 14/2 to the first, but ran 14/3 to them all.
Massachusetts code on smokes Clutchcargo Electrical 14 08-11-2010 11:18 PM
Interconnected smokes CowboyAndy Electrical 6 02-20-2008 12:03 PM
Interconnected Smokes capt2 Electrical 6 02-01-2008 07:32 PM
hardwiring vs. plugs A.Pierce Electrical 3 01-27-2008 08:05 PM
dishwasher hardwiring help dexterinmiami Electrical 5 12-30-2005 12:10 AM
