Hardwired Smoke Alarms - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2010, 01:32 PM   #1
Rewards Points: 358
Our home was remodled before we bought it and they shrunk the kitchen and extended the mater bedroom. Long story short I have (2) smoke alarms in my master bedroom and they are only about 7 feet apart from eachother. Can I just unplug it and patch the hole in the ceiling, and leave the wires as is in the attic space? I am just worried if I unplug it, it may effect the rest of the system somehow.
Thanks!
cbzdel is offline   Reply With Quote
Old 05-20-2010, 04:22 PM   #2
Electrical Contractor
kbsparky's Avatar
Are both smoke alarms part of the same system?
I've seen houses where a central alarm system included smoke detectors, and those were different from the normal stand-alone battery/electric units commonly installed in houses today. Local codes required the hard-wired battery-electric units, even if there was a central alarm system installed.
IF you remove either of them, and there is wiring present in the box, then you will have to install a blank plate to ensure accessibility later on. You can't just patch over a junction box, unless all the wiring is disconnect or removed first.
-KB
Old 05-20-2010, 05:17 PM   #3
Rewards Points: 358
My plan was to flip the junction box unside down and attach to a joist and then cap it off, and then fill in the hole. That way everything is still accessible.
Also this is not an alarm system it is just a hard wired smoke alarm with battery backup. They are all hooked up together so if one goes off they all go off.
Old 05-20-2010, 05:19 PM   #4
As long as they are both smokes only, & one is not a CO or combo smoke/CO then you should be OK
Only 1 required in a bedroom
Old 05-20-2010, 05:33 PM   #5
kbsparky's Avatar
Flipping the j-box up into an unfinished attic, where it would be accessible is a viable option.
I see no problem with that solution.
-KB
Wiring for residential smoke alarms under 2008 NEC jeffers Electrical 13 05-13-2010 09:51 PM
Smoke Alarms Just Would Not Stop lundyg Electrical 2 12-30-2009 08:09 AM
AC Smoke alarms - Nuisance Alarms jamiedolan General DIY Discussions 8 10-27-2008 07:56 AM
Hardwired Smoke Detector question NateHanson Electrical 18 11-10-2007 08:10 PM
12 Smoke Alarms sootybuttercup Electrical 8 09-19-2006 08:06 PM
