Hardwired Doorbells And GFIC - Electrical - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 10:45 AM   #1
Rewards Points: 726
hardwired doorbells and GFIC
I just installed a hardwired doorbell (got sick of wireless needing new batteries every month.....)
its on our "outdoor" circuit... anything that is outdoor went on this when the house was built... which is GFIC protected..
now my questions
should the bell be GFIC protected?
should the bell be on its own circuit or is a generic outside circuit ok? All that is on it is is 4 outside outlets
BlueBSH is offline   Reply With Quote
Old 07-30-2010, 12:06 PM   #2
the Musigician
DangerMouse's Avatar
I thought you were going to say the GFCI tripped whenever someone rang the doorbell! -=chuckle=-
I do not believe it has to be on it's own circuit, nor on a GFCI, but it won't hurt it if it is.... and, of course, I could be wrong!
DM
Old 07-30-2010, 12:37 PM   #3
I=E/R
a7ecorsair's Avatar
Where did you mount the transformer? Apparently you have a junction box somewhere inside to do this.
a7ecorsair is offline   Reply With Quote
Old 07-30-2010, 01:01 PM   #4
Rewards Points: 726
Yes the Service entrance room has a line (20Amp 110v) going from a breaker marked as "Outside electical" on the panel into a two gang metal box which has a single GFIC outlet on it (mounted center of the box with a metal cover plate on it) then that on the side has one of the knockout's punched out and the transformer is mounted there and wired up to the Line side right now not the load side because I wasn't sure which one to use for this situation or if a transfomer like that should be on the GFIC side... was planning on moving it if I had to onto the load side... then the wires from the buttons and bells all come back to that area and terminate there and are wired from that point up
Old 07-30-2010, 01:30 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 702
I don't think it makes any difference if you are connected to line or load side of the GFCI. The low voltage wiring is isolated from the high voltage by the coil of the transformer.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 07-30-2010, 01:32 PM   #6
Rewards Points: 726
Good to know, thanks. I just wanted to make sure I was up to code with this.
