Hardwire An Outlet - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By CodeMatters
Old 09-23-2019, 08:16 AM   #1
Rewards Points: 2
Hardwire an outlet
Hi, I had an old range hood removed that was hardwired in. The new range hood is a plug in. Can the wires ( there are three wires) from the old range hood be used to wire a plug in outlet. The wall open so putting a box in will be easy.
Squire20 is offline   Reply With Quote
Old 09-23-2019, 08:25 AM   #2
CodeMatters's Avatar
Rewards Points: 7,938
Re: Hardwire an outlet
Yes..
Domo likes this.
CodeMatters is online now   Reply With Quote
Old 09-24-2019, 08:48 PM   #3
Rewards Points: 466
If you are in the US, NEC 422.16(B)(4) requires that receptacle be a dedicated circuit for a range hood. If hardwired, the hood can be on a general lighting circuit. Reason for the distinction being microwave hoods are cord and plug connected, and might be installed in place of the vent hood at some point.
jhil is offline   Reply With Quote
