Hard Wiring Dishwasher Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 07:04 PM   #16
dSilanskas's Avatar
Originally Posted by Scuba_Dave View Post
Ahhh..va - missed that somehow
Yeah that changes things
Isn't a 40a/50a hard wired stove an appliance ?
So that should mean hardwired stoves & appliances also need lockouts on the breaker ?
I still think with an appliance Off is Off...no need for another disconnect in a residential setting
422.34 states that if the control has an OFF position then switch is not needed
Stoves & dishwashers have an OFF position
So for one family (C) applies - breaker is OK
dSilanskas is offline   Reply With Quote
Old 06-01-2010, 12:10 AM   #17
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by brric View Post
Nap, just my observation, the inspectors we deal with in Berrien County, MI do not enforce this for residential installs.
You really don't think Simpson would enforce it? He is notorious for being a nit picker.
I'll have to remember to call him soon and ask.
Old 06-01-2010, 12:25 AM   #18
nap
You talking to me?
nap's Avatar
breaker is fine if it either is in view of the appliance or that has a locking ability.
and even in 422.34(C),did you miss in the main paragraph where it says:
the switch is acceptable as the disconnecting means WHERE OTHER MEANS OF DISCONNECTING ARE PROVIDED IN OCCUPANCIES as specified in 422.34(C).
then look down in C and it states: the service disconnecting means shall be permitted to be the OTHER disconnecting means.
That still does not remove the requirement of 422.21(B). You still have to have the lock on it
The point of this is not just to kill power to the unit. How do you propose changing the dishwasher with just turning the old on off?
Old 06-01-2010, 05:08 AM   #19
dSilanskas's Avatar
Turn off the breaker. I can understand what your saying if it was a commercial kitchen but its not.
Old 06-01-2010, 07:01 AM   #20
DIY Expert in Training!
Just to make sure I'm on the right page...I will now hardwire the DW to the box. To secure the wire I will use a metal face plate with a punch out for a wire clamp. This will keep the wires secure. All ok?
Thanks!
gone_fishing is offline   Reply With Quote
Old 06-01-2010, 03:38 PM   #21
nap
You talking to me?
nap's Avatar
there is no exception for residential
Old 06-01-2010, 03:39 PM   #22
nap
You talking to me?
nap's Avatar
Thanks!
If you are using a plastic box, I would suggest using a plastic faceplate. If you use a metal faceplate and a plastic box, you have to figure out how to bond the faceplate to the EGC (ground wire).
Old 06-02-2010, 01:09 PM   #23
metal box, metal plate.
Old 06-02-2010, 02:42 PM   #24
nap
You talking to me?
nap's Avatar
then all should be fine. Just make sure you bond the EGC to the box. The contact of the cover to the box would provide the necessary bond for the cover.
The Following User Says Thank You to nap For This Useful Post:
gone_fishing (06-03-2010)
Old 06-03-2010, 05:03 AM   #25
Rewards Points: 2,068
I wouldn't hard wire the dishwasher I always think about service after the fact.. I would extend the outlet to the next cabinet where the water and drain are and leave extra cord (approved) on the dishwasher and plug it in under the sink. You never know when you need to unplug it in a hurry or just for on the spot service. It is also easier to install as you push the dishwasher in you feed the cord through to the other cabinet.
COLDIRON is offline   Reply With Quote
Question about series wiring. Chevyman30571 Electrical 7 02-26-2010 08:54 AM
Electrical Box Wiring Question OmahaGirl Electrical 9 02-18-2010 08:03 AM
carrier 48ss-042 wiring Question bekind42 HVAC 3 06-15-2009 05:54 PM
Series wiring question. ingeborgdot Home Theater 2 05-29-2009 09:01 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
