Hard Wiring Appliances - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2010, 04:52 PM   #1
hard wiring appliances
I just discarded my range hood, which was little more than a light over the area, and would like to mount my small counter-top microwave on a shelf in it's place. The range hood had been hard wired...can I do the same with the microwave? If so, HOW?
marg gurr is offline   Reply With Quote
Old 03-29-2010, 05:05 PM   #2
Where are you located ?
What else is on that circuit ?
Old 03-29-2010, 06:59 PM   #3
Master Electrician
your going to get alot of heat on that shelf make sure it's protected. You can hard wire the microwave but why bother? You can't just run a romex into it if that's what you asking. You'd have to install the range hood feed into a box as per your local code and then cut the cord cap off the microwave and tie it into the box as well. Easier probably to just install a plug using the range hood wire and plug into it.
andrew79 is offline   Reply With Quote
Old 03-30-2010, 12:27 AM   #4
electrical instructor
No you can not hard wire an appliance. It must have a disconnecting means (receptacle). Take the hood feed and put it in a handy box with a receptacle. THE ONLY PROBLEM IS THAT MICRO'S USE A LOT OF POWER. YOU MIGHT START TRIPPING THE CIRCUIT, IF SO, YOU MIGHT HAVE TO RUN A NEW CIRCUIT
bhound84 is offline   Reply With Quote
Old 03-30-2010, 10:42 AM   #5
Licensed electrician
Rewards Points: 3,662
If this is a microwave hood it will need a dedicated circuit per the installation manual.
There may not be enough clearance from the stovetop either.
Old 03-30-2010, 11:21 AM   #6
Master Electrician
thanks for the clarification on that...i thought that's how it had to be but i wasn't sure.
he said it's just a counter top microwave.
wiring overkill????? choda_boy_04 Electrical 8 01-01-2009 12:54 PM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 03:56 PM
Electrical problem, bad wiring? mumblemouth Electrical 10 08-09-2008 11:52 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
