Handy Box Extensions - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By CodeMatters
  • 1 Post By Oso954
Old 11-13-2017, 09:07 PM   #1
Rewards Points: 54
Handy box extensions
I am trying to find a box extension for handy boxes. I need to extend them out 5/8". Any ideals?
Bill
Sent from my SM-G920V using Tapatalk
billkater is offline   Reply With Quote
Old 11-13-2017, 09:28 PM   #2
CodeMatters's Avatar
Rewards Points: 7,938
Re: Handy box extensions
Don't know if an extension is available or not, but have to wonder why
one might need to extend a surface mount box?
CodeMatters is online now   Reply With Quote
Old 11-13-2017, 09:29 PM   #3
Licensed electrician
Rewards Points: 3,832
I would change out the box.
Old 11-13-2017, 10:08 PM   #4
Rewards Points: 54
A guy I am helping. Older guy (65 or so) insisted that we use them for outlet boxes. We ran conduit to them all and covered with drywall. I told him that there wasn't and way to extend them to the face of the drywall. He insisted there was and was the one paying the bill. So I did as I was told.
If I have to I will get the extenders that slide in the box and shim behind the screws. Don't want to but to late to change out the boxes.
Old 11-14-2017, 01:00 AM   #5
Rewards Points: 3,008
How about https://www.amazon.com/Arlington-Non.../dp/B0078848FA
(Can't find the depth but it looks about right. You could always use two !)
FrodoOne is offline   Reply With Quote
Old 11-14-2017, 01:22 AM   #6
Rewards Points: 54
Saw those. Not cheap.
Old 11-14-2017, 01:43 AM   #7
Cheaper here (https://www.homecontrols.com/Arlingt...xtender-AABES1) - but they probably don't include postage !
You could try an Electrical supply store. May require a special order.
Old 11-14-2017, 07:05 AM   #8
Rewards Points: 760
These are metal (handy box extensions) and they slip inside the existing handy box. It makes it adjustable in depth. Push it into the existing handy box so the flanges meet flush with the wall surface.
afjes2015 is offline   Reply With Quote
Old 11-14-2017, 07:09 AM   #9
If someone insisted on using the wrong materials I'd just walk away.
He thinks he knows how to do it, let him fix and finish it.
Jim Port and Mike Milam like this.
The Following User Says Thank You to CodeMatters For This Useful Post:
Jim Port (11-14-2017)
Old 11-14-2017, 08:26 AM   #10
Looks like they used the center back knockout. Going to make it hard to get the devices in. Boxes might be overfilled also.
Old 11-14-2017, 11:32 AM   #11
Oso954's Avatar
Rewards Points: 1,808
Looks like #14 romex. Sure hope that's a lighting circuit, not a kitchen or bathroom receptacle circuit.
Jim Port likes this.
Oso954 is online now   Reply With Quote
window jamb extensions too short. ideas? itsnotrequired Windows and Doors 5 04-24-2012 04:22 PM
Table saw extensions Justins1171 Tools 5 11-23-2011 03:30 PM
Clearing Out Clogged Downspout Extensions sweaty Plumbing 4 08-08-2011 11:01 AM
Sizing Jamb Extensions smacman Building & Construction 3 06-29-2010 12:06 PM
