Halo H50 Trim Instalation - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 01:17 PM   #1
Halo H50 Trim instalation
Hi all.
Let me start from i had alot of trouble finding anything that fits into this housing and nobody seems to know witch trim i actually need.
So i found some lights store that told me any 5" trim would work, so i got
one basic 5" trim with reflector to check... Problem seems that 2 springs that supposed to hold it are to long and trim hangs 1" below sealing...
Any Ideas, Recommendations...
Please anything might help...
Borik
Borik is offline   Reply With Quote
Old 11-11-2010, 02:07 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 946
Inside the can, where the lamps goes, is a list of halo trims to fit that can light.
I can not find any recessed light from halo with H50.
Are you sure you have the right number?
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 11-11-2010, 02:28 PM   #3
Hi
thank you for reply, i think i got the number correct...
but just in case attaching image...
It could be very old hosing, i just don't know.
Borik
Old 11-11-2010, 03:33 PM   #4
jbfan's Avatar
Rewards Points: 946
Originally Posted by Borik View Post
Hi
Borik
That's the label I was talking about.
You may have to call an electrical supply house and have them order them for you.
I looked in my books and online and did not find anything.
Old 11-12-2010, 08:54 AM   #5
Can you please recommend one? Or Suggest how to go about find one?
Borik
Old 11-12-2010, 09:46 AM   #6
jbfan's Avatar
Rewards Points: 946
Where are you located?
http://www.cooperlighting.com/conten...talk_to_us.asp
Cooper Lighting contact info.
Old 11-12-2010, 10:38 AM   #7
I am in Brooklyn, NY
Borik
How to remove trim from Halo recessed lighting?? rdiggidy Electrical 7 09-05-2013 06:00 PM
Halo Recessed Light & Trim Compatability GeauxCajuns82 Electrical 2 04-27-2010 11:17 AM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
Cheap Halo recessed Trim fixtures? ahreno Interior Decorating 2 05-09-2009 07:17 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
