Guitar Amp Hum - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 02:14 PM   #16
Just call me Andrew
Rewards Points: 1,032
Originally Posted by DangerMouse View Post
I talked Tommy into getting one for his lead, he also uses a zoom.
We love dancing with the gals while we jam out front....
DM
I used a Zoom looong ago. I ended up getting this vintage Alesis Quadraverb rackmount midi effects unit. $80 well spent!
Andrew
secutanudu is offline   Reply With Quote
Old 03-04-2010, 02:27 PM   #17
the Musigician
DangerMouse's Avatar
I still love my rackmount DSP16... it's older but it still kicks. #66 is perfect for my vocals. Tommy only uses that setting too for his vocals. (check out Greedy King Pete video on youtube and you can hear it. Link below.)
I ran it straight to my laptop to do the vocals for that song.
I also used the laptop for everything else I played too. Bass, 12 string guitar, drums, chimes and tambourine.
(Tommy supplied the lead guitar riffs)
DM
Old 03-04-2010, 02:31 PM   #18
Just call me Andrew
Nice, I'll check it out.
Our one "video" (friend in college did it for a school project):
Andrew
Old 03-04-2010, 02:49 PM   #19
the Musigician
which one is you?
remember, I'm on dialup... it's about 1/4 loaded...
DM
Old 03-04-2010, 03:13 PM   #20
the Musigician
I liked the middle 8... and the ending was good.
DM
Old 03-04-2010, 03:50 PM   #21
I'm sure you know if you have a single-coil pickup guitar (like a Stratocaster) hum is un-avoidable (unless you lean the right way so the RF is minimized). If your guitar is humbucker-equipped, than you might have a ground loop in your guitar->pedals-> amp rig. If your amp rig is a seperate preamp & power amp, than you can leave the power amp 3-prong grounded & lift (with a 3->2 adapter plug) the preamp's ground.
It's a good idea to test your home wiring like you plan (ned) to do. Specially if your rig is hum-free at another house.
Are you using rack gear? If it's in an Anvil case, with metal edges, and you're using 2 or 3 different rack effects, the can get a loop hum when all the individual rack ears touch the metal rack case. I ran into that a while back, and got a few sets of isolation plastic tabs that go between the rack ears and the case's rack rails - they're called "Hum-frees" and the work.
Just my $.02.
Originally Posted by Thundergod View Post
I am getting a bad hum/buzz in my guitar amp. I believe it is because my house isn't grounded. I am going to confirm it tomorrow with an outlet tester. If it isn't grounded....what are my options.
1. Should I get a dedicated circuit put in
2. Would plugging the amp into an isolation transformer work.
SixStrRzr is offline   Reply With Quote
Old 03-04-2010, 05:58 PM   #22
Just call me Andrew
DM
I'm the idiot with the earphones on.
Andrew
Old 03-04-2010, 06:07 PM   #23
My bet is he forgot to bookmark the site & won't be back
Old 03-04-2010, 06:10 PM   #24
the Musigician
I'm guessing the little ditty I wrote the words and music for isn't exactly your taste.... lol
Oh well.... I also did all the music on the other videos there.
DM
Old 03-04-2010, 06:48 PM   #25
no this is normal...all single coil guitars will have the "60 cycle hum" as you described...the only way to get rid of this is have a reverse wound single coil a humbucker coil or you can buy hum canceling pedals too...ive been playing for over 13 years
joseph2293 is offline   Reply With Quote
Guitar Pedalboard..help please with MDF! christam1 General DIY Discussions 1 02-22-2008 04:46 PM
What songs on Guitar Hero III are the hardest for you to beat? Fira Off Topic 2 11-17-2007 07:19 PM
