Grounding Two Prong Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2015, 08:30 PM   #1
Rewards Points: 4
I have an older 1950s style home that I recently purchased. Unfortunately their are old style two prong outlets. I want to install 3 prong outlets but safety is a big concern. I know the outlets have to be grounded to install a 3 prong. I went around the house and checked the outlets with a surge protector I have. The surge protector has a light to indicate if the outlet is grounded or not. Some of the outlets showed a strong green light meaning they were indeed grounded. However, other outlets displayed a weaker, dim green light. I guess meaning the ground is weaker at those outlets. I took it a step further and popped out the old outlets. I used a tester, one end on hot other on metal box. It lit up showing there is some kind of ground. Upon further inspection, I noticed that there appears to be copper ground wire wrapped around a screw on the inside of the box. My question is, is this setup ok for now? The copper is too short to reach the ground screw on the new outlet.
I just had new service line, outside panel and breaker box installed, and ground wire ran outside from the box. Am I good to go? Should I still consider GFCI?
Mike
mcway is offline   Reply With Quote
Old 01-28-2015, 08:35 PM   #2
Licensed electrician
Rewards Points: 3,740
The upgraded system ground has nothing to do with the branch circuit ground or the third prong on the receptacles.
Three prong receptacles can be used on a two wire system without a ground if gfi protected and labeled "no equipment ground".
A push in connector can be used to extend the short ground to reach the device and also allow the box to be grounded.
Old 01-28-2015, 08:39 PM   #3
Rewards Points: 4
ok thats what I wanted to make sure of. I will use a push in connector. I was thinking about adding GFCIs also just for some extra piece of mind. Thank you
Old 01-28-2015, 08:56 PM   #4
Rewards Points: 1,832
GFCIs are wont hurt, they are a good idea.
Jump-start is offline   Reply With Quote
Old 01-28-2015, 09:57 PM   #5
Msradell's Avatar
Rewards Points: 1,006
Assuming he really does have a good ground at each receptacle there is no need nor reason to add GFCIs to circuits they are not required on!
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 01-28-2015, 10:00 PM   #6
True, but considering we have no way of knowing the true integrity of his EGC system it wouldn't be counterproductive.
Old 01-28-2015, 10:20 PM   #7
Rewards Points: 138
"No equipment ground" label
Where should you affix the "no equipment ground" stickers that come with the GFCI outlets? On the wall plate? On the outlet under the wall plate (seems counter productive to me)? Should you put a sticker on all three prong outlets downstream of the GFCI?
Underestimater is offline   Reply With Quote
Old 01-28-2015, 11:35 PM   #8
The sticker should be on the plate itself on every none grounded GFCI protected 3 prong outlet.
The Following User Says Thank You to Jump-start For This Useful Post:
Underestimater (01-29-2015)
Old 01-29-2015, 02:35 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 328
If the metal box is grounded, use self grounding receptacles.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
MTN REMODEL LLC (01-29-2015)
Tags
gcfi , ground , outlets , wire
converting furnace to normal power outlet vivithemage HVAC 28 01-24-2015 02:00 PM
What do you call this electrical outlet switch adapter and is there a 3 prong version daluu Electrical 7 01-10-2015 07:18 PM
Grounding outlet ALWavada Electrical 3 05-28-2012 02:38 PM
Grounding Outlet Delyrium Electrical 4 06-19-2011 03:26 PM
dryer Outlet change 3 prong to 4 prong oldpirate General DIY Discussions 2 08-06-2008 06:18 PM
