Grounding A Square Box <--newbie Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 02:49 PM   #16
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
If you don't want an out let there I would mount it on top to the right of the stud cavity the panel is in. Be careful when you cut the hole to not damage the wires that are there and put a single gang box in with romex 12-2 running to the panel. Then mount and exteral metal box to that make it a double wide. Ground the box and run you conduit from there. From that point on there is no need for a ground but I would still run one. No need that is if you ground every box to the device in the box be it a light or plug or whatever. Don't waste the money on a GFCI outlet if you are putting a GFCI breaker in.
Big N8 is offline   Reply With Quote
Old 01-06-2010, 02:58 PM   #17
Rewards Points: 47
...follow up reply
Thanks for the respone Big N8.
Sorry if I sound dumb here...
So the single gang box you mention would go inside the drywall (like all the other outlets in the house), and would it be metal or blue/grey plastic?
How do you affix the other double wide metal box on the outside to it then?
Thank you again everyone for the help!
dgates12 is offline   Reply With Quote
Old 01-06-2010, 03:25 PM   #18
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Here is the single gang box I would use and mount it flush with the wall.
http://www.licensedelectrician.com/Store/SmartBox.htm
and here is the metal box i would attach to the single gang.
http://www.thecollegetoolbox.com/ra4sqex1de13.html
So you will be staking the boxes on top of each other. that will be you transition from behind the wall the exposed conduit.
Old 01-06-2010, 03:30 PM   #19
Rewards Points: 47
Sweetness.
I'll see if I can find one of these Smart Boxes locally, all I've seen at HD are the old work boxes that have the tabs that flip up when they tighten to the sheet rock underneath.
Thanks for the idea.
Old 01-06-2010, 05:56 PM   #20
Electrical Contractor
jbfan's Avatar
Rewards Points: 960
I would use a 1900 box, mounted to the stud on the right, drill a small hole in the sheetrock and feed a cable down to the panel.
Add the conduit to the box and you have one less connection to worry about.
Run 12/2 and use a 20 amp breaker..
Use a gfci receptacle at the first location and feed the rest of the circuit.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 01-06-2010, 06:02 PM   #21
Rewards Points: 47
Thanks for the input, great suggestion as well.
grounding question Skippymartinez Electrical 1 11-30-2009 07:19 AM
Question on QO-20M Square D panel rovers1973 Electrical 6 02-06-2009 08:07 PM
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 09:50 PM
Newbie question about crack in PVC joint LinusInPW Plumbing 8 11-16-2007 11:25 PM
