Grounding Rod - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 08:40 PM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Grounding Rod
I am trying to put a grounding rod in near the pump for my pool. The previous owners were not fond of codes, apparently. Anyway, I can get this thing pounded through the top 6" of topsoil, until I hit our super-rock pitrun that is common in this area.
1. How deep do I need to get this rod in the ground?
2. Is there a better way to do this than just trying to whack it with a hammer (Rocky ground. Really rocky).
hyunelan2 is offline   Reply With Quote
Old 06-01-2010, 08:46 PM   #2
Master Electrician
Rewards Points: 5,082
Properly installed pools DO NOT require ground rods.
brric is online now   Reply With Quote
Old 06-01-2010, 08:59 PM   #3
hyunelan2's Avatar
Rewards Points: 692
When I had an electrician out to do some work for me, he told me that the pump body needed to be attached to a grounding rod. I never questioned that until now. After looking into it - it looks like that screw is for the bonding connection, and my pool is not properly bonded.
This is an above-ground pool, btw.
Old 06-01-2010, 09:10 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
brric is correct.
Pool BONDING does not, and has never, required ANY grounding electrodes. Many seasoned electricians are even not clear on this, obviously.
Connecting from the lug on the motor to a ground rod will do NOTHING at ALL.
Same goes for the bonding. There is NO requirement or need to extend the bonding wire back to a panel or electrical circuit.
Old 06-01-2010, 09:16 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
and when you do install the bonding grid, don't forget the pool frame and walls, if metal, and the water itself.
grounding electrode conductor question bsperr Electrical 8 12-05-2009 09:23 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
Grounding light box n0c7 Electrical 10 10-06-2008 03:20 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
