Grounding Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2009, 07:14 AM   #1
grounding question
Hi I have a question about grounding ? a two unit building in has one service drop from the pole then is split in to two meters. I am a liittle confused there are two seperate panels inside one panel GEC is coonected to the cold water pipe No GEC for the other panel. Shouldn't each panel have a ground? Can they use the same water pipe does this create a problem?
Skippymartinez is offline   Reply With Quote
Old 11-30-2009, 07:19 AM   #2
Remodeling Contractor
The ground from the water pipe and ground from a grounding rod both go to the main distribution panel. If these two panels are feed from a meter/disconnecting box then the grounding goes into this box only. A four wire feed is used to feed the two sub panels. All ground wires and neutral wires are separate after the main disconnecting means.
4 pin dryer to 3 pin (grounding question)? nadazip Electrical 6 07-06-2009 10:00 PM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 05:48 PM
Sub-panel grounding question. gesoneguy Electrical 31 02-22-2008 08:25 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 01:49 PM
