Grounding Problems? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 09:46 PM   #1
Question
grounding problems?
my daughter just moved into a house. She has found that when she runs the washer or dryer it causes her computer upstairs to flicker and also causes fine lines on the tv? I am thinking this may be a simple ground problem but am not sure how to approach this. any help would be welcome!!! Thanks!
jrum298 is offline   Reply With Quote
Old 04-29-2010, 09:28 AM   #2
Does running a hair dryer from the washer outlet cause the same problem?
Old 05-01-2010, 09:32 PM   #3
Question
hair dryer
sorry for my delay...yes hair dryer causes same problem as washer/dryer. the interference remains the same
Old 05-02-2010, 08:54 AM   #4
Rewards Points: 2,800
It could be (1) a grounding problem, (2) a dirty power problem, or (3) through the air interference problem.
A makeshift ground can be made by stringing a long wire from a known ground, up over door ways and along baseboards with the end screwed to the chassis of the computer (easy with most metal bodied PC's). With a pigtail connected to the chassis of the monitor, held on by the screw that holds the VGA computer cable to the back of the monitor is one way of connecting.
Most surge suppressor power strips also "clean up" "dirty power" that is reduce or eliminate wire borne interference that leaked into the line, possibly from a plugged in motorized appliance, namely remove frequency content other than the 60 Hz of the power itself.
If the washer, dryer, etc. was not properly grounded, it may be more likely to generate airborne or wire borne interefence.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 05-03-2010, 10:55 AM   #5
I'd say it's a high resistance connection upstream of the washer and the computer, which lowers the voltage to the computer.
Check the voltage at the washer outlet while you switch the hair dryer off to on and back; a 3v drop [e.g. from 120v to 117v] from off to on is about normal.
Old 05-03-2010, 11:24 AM   #6
Licensed electrician
Rewards Points: 3,654
Are the washer and dryer on the same circuit as the bedroom? does this problem happen whenever a large motor load is in use?
Old 05-03-2010, 09:29 PM   #7
Thumbs up
ground Problem
Thanks to all for your help!! I will use your direction and let you know what I find ( if anything). Hope to get over there later this week.
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
An outlet died, how to find out where it is connected and grounding problems Korhan Electrical 3 09-23-2009 05:52 PM
Bizarre Electrical Problems - Grounding? CaptHanky Electrical 45 06-27-2008 09:18 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
