Grounding An Old Appliance - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2019, 09:00 PM   #1
Rewards Points: 38
Grounding an Old Appliance
I’ve just replaced an old two-wire circuit with a fresh, grounded one. I want to keep using a small space heater on the circuit, but the heater only takes two wires, and has no grounding lug. Can I add a ground to this appliance? My idea is to solder or bolt a lug to the case, and then connect the circuit’s ground wire to it.
Rollie83 is offline   Reply With Quote
Old 11-09-2019, 09:02 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,946
Re: Grounding an Old Appliance
If the heater was manufactured with a 2 prong plug there is no need to add a ground. It has been tested and certified for 2 prongs.
Old 11-09-2019, 11:49 PM   #3
Rewards Points: 38
joed, thanks, but there is no plug, it's a hard-wired appliance. It's installed in a moist environment (bathroom), and I've always been just a little nervous about a shock hazard for that reason. I've had it apart, and seen that the heating coils and electrical connections are set off by thin, little, disk-shaped insulators, but I've always imagined them cracking with age. Would there be any harm or risk to me grounding the case?
Old 11-10-2019, 06:50 AM   #4
Super Moderator
joed's Avatar
There would be no harm in grounding the metal case. Being hard wired I am surprised there is no place for the ground wire to connect. Do not solder. Use a bolt and clean the paint off to make a good contact.
Old 11-10-2019, 03:18 PM   #5
Rewards Points: 38
On second look, I found an existing screw that will hold a ground wire quice nicely. Thanks for the help.
