Grounding Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2013, 10:07 AM   #1
Grounding Issue
Hi all,
I'm currently trying to install a wall sconce, but I'm having a bit of difficulty.
The previous owners had sconces, but I'm not sure if their set-up was safe. I've taken some pictures to help. Here's the deal:
Rather than a junction box, they appear to just have wires sticking out of the wall (one 'hot' wire and a 'neutral'). There is no ground wire. Additionally, the mounting bracket for the sconce isn't attached to any box, it's just drilled into the wall.
The sconce, on the other hand, has a hot wire, a neutral wire, and a ground. So, basically, my question is this: Should I ignore the ground wire altogether? Or should I attach a small nut to the mounting frame to act as a grounding nut? OR, is this setup just wildly unsafe?
Since the sconce, itself, is metal and is operated by a switch on the device, I'm very concerned about the risk of shocking someone. Thank you so much for the help.
Here are the pictures:
casey56 is offline   Reply With Quote
Old 05-19-2013, 10:17 AM   #2
Master Electrician
Rewards Points: 5,266
You need a junction box installed in the wall. The bracket attaches to the jbox.
brric is online now   Reply With Quote
Old 05-19-2013, 10:29 AM   #3
Licensed electrician
Rewards Points: 3,742
If you cut back the jacket of the cable you may find out the ground has been cut off.
Grounding sub-panel at pool house CraigMW Electrical 12 08-19-2011 10:08 AM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 08:19 AM
Swimming Pool Grounding Issue Islander Electrical 20 09-02-2009 10:27 AM
Sub Panel Grounding bar bmancanfly Electrical 12 05-24-2009 02:07 PM
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
