Grounding Barn Slabs - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2009, 02:09 PM   #1
R_T
Grounding barn slabs
Does anyone know if it is necessary to ground the slab next to my barn? How would I do it?
R_T is offline   Reply With Quote
Old 07-20-2009, 02:17 PM   #2
You sometimes use the rebar in a footing as a ground for the electrical service, but you don't ground slabs.
220/221 is offline   Reply With Quote
Old 07-20-2009, 02:42 PM   #3
J. V.'s Avatar
Rewards Points: 348
If I was pouring a slab and was using rebar, I would install a UFER. Search UFER on this site. You may need it one day and it is very easy to do if you do it now. It will come in handy should you build anything on this slab and want power there.
Old 07-20-2009, 02:50 PM   #4
R_T
I guess I wasn't clear enough. I've heard that when you have livestock that stand or walk on slabs that have steel in them, the slabs have to be grounded, especially if their is electrical servive in the building, barn, etc. attached to the slab. I believe it is for protection for the animals. Something about ther acute sensistivity to current because all four feet are on the ground and any current passes through their heart. I'm wondering if I have to ground to the panel or a ufer.
Old 07-20-2009, 03:07 PM   #5
I've never heard of the livestock/grounding thing. Sounds like BS to me....but I'm a city boy
Look at you panel and see if there is a big, probably bare copper wire running out of it into the ground/concrete.
It is used to allegedly give lightning a path to ground (as opposed to it going into your electrical system and coming out of your stove )
Old 07-20-2009, 03:34 PM   #6
zpm
yeah, right
547.10(A)(2)
(2) Outdoors.
Equipotential planes shall be installed in
concrete slabs where metallic equipment is located that
may become energized and is accessible to livestock.
The equipotential plane shall encompass the area where
the livestock stands while accessing metallic equipment
that may become energized.
547.10 ... "the term livestock shall not include poultry."
So fried chicken is OK, but fried pork rinds ain't.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 07-20-2009, 04:15 PM   #7
R_T
zpm - multiple thanks yous.
Old 07-20-2009, 10:17 PM   #8
WFO
I think this is primarily for dairies where there are automatic milkers. In this case, the ground potential is very critical. Unless your cow is into S&M, it won't like a poorly grounded slab/
If you just have a slab that your cows stand on out of the rain while they eat, I don't think it's that big a deal.
WFO is offline   Reply With Quote
Old 07-21-2009, 11:28 AM   #9
J. V.'s Avatar
Rewards Points: 348
You never mentioned livestock in your original post. Yes, there are electrical precautions for livestock. Namely GFCI protection. I would install the simple UFER if you plan to put a panel in this area. If no panel, then a GFCI breaker or receptacle would be all you need.
Old 07-21-2009, 04:07 PM   #10
Rewards Points: 150
Not sure where this would fit in.
http://www.omafra.gov.on.ca/english/...s/strayvol.htm
Gary
Gary_602z is offline   Reply With Quote
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 10:58 PM
Grounding circuits in barn businmike Electrical 2 06-01-2008 09:22 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
