Grounded Neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 02:03 PM   #1
Rewards Points: 726
Grounded neutral
What is a grounded neutral and how do I prevent it? I was reading that some AFCI breakers have problems with grounded neutrals, what exactly should I be looking for?
BlueBSH is offline   Reply With Quote
Old 09-23-2010, 02:19 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
well, by definition, a neutral is a grounded conductor so, a neutral is a grounded conductor by design,
so, that means, to me, you don't want to prevent it.
the only thing I can think of is a neutral that is grounded some place other than the only place it is allowed which is at the main service disconnect.
Old 09-23-2010, 02:22 PM   #3
Rewards Points: 726
that's why I am confused why my instructions say check for grounded neutrals.... because even at the service panel neutral is bonded to ground so its basically the same thing
Old 09-23-2010, 02:24 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
This is why things like this should NOT come with instructions.
Old 09-23-2010, 02:24 PM   #5
I=E/R
a7ecorsair's Avatar
Make sure the branch neutral is connected to the AFCI and the AFCI white wire is connected to the neutral bar in the panel.
a7ecorsair is offline   Reply With Quote
Old 09-23-2010, 02:29 PM   #6
nap
You talking to me?
nap's Avatar
OOHHH!!! I get it now, I think.
It sounds like a very poor instruction but typically, the neutral from the circuit will be connected to the neutral bar which in the main panel, is also ground i.e a grounded neutral. As corsair states, the circuit neutral must be removed from the neutral bar and connected to the breaker. The neutral from the breaker will then be connected to the neutral bar.
Old 09-23-2010, 03:13 PM   #7
Rewards Points: 726
Of course it says check for grounded neutrals right after it tells you how to connect it and even shows a diagram of the branch circuit being wired to the breaker and the pigtail to the neutral bus.... anything to confuse people
Old 09-23-2010, 03:30 PM   #8
nap
You talking to me?
nap's Avatar
just feel lucky the instructions are in English.
Old 09-23-2010, 08:32 PM   #9
" Euro " electrician
frenchelectrican's Avatar
Not always the case few time I have some insturctions are in very poor English at all ditto with French I have ran into more than once UGHHHH.
Merci.
Marc
Old 09-24-2010, 06:18 PM   #10
Union Electrician
goose134's Avatar
I had to hang an Italian sconce that wasn't agreeable to American boxes. The instructions would have been great if I spoke Italian. This experience has led me to the belief that the more you pay for a fixture, the harder it will be to install. This relationship is inverse with fans.
goose134 is offline   Reply With Quote
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
question on the "stubbie" bonding links n175h Electrical 12 10-13-2009 04:09 PM
GFCI feeing subpanel question scott2332 Electrical 45 02-28-2009 03:15 PM
Electrical connections TazinCR Electrical 11 01-07-2009 07:10 PM
Grounded electrode on water pipe TW Lucas Electrical 7 05-12-2008 11:33 AM
