Ground/shock Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-19-2010, 11:30 PM   #16
Rewards Points: 150
If I may ask RS, which field did you start in? Electrical or electronics?
emolatur is offline   Reply With Quote
Old 11-19-2010, 11:33 PM   #17
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Actually, computer science. Most of what I know about electrical I learned myself or from others. When I was young I actually wanted to be an electrician, then ended up getting into computers which lead me to IT.
I started playing with electrical around the age of 12. It all started with a paper clip, a light bulb, and a small wire. Lot of shocks and sparks down the road from that point.... LOL
Old 11-19-2010, 11:38 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you did better than many. A lot start with just a paper clip
Old 11-20-2010, 12:30 AM   #19
Rewards Points: 150
lol. Kinda where I am. I started with... uhh... electrical I guess, just hooking lights to batteries and discovering series circuits "the hard way"... at that time my interest was electronics - audio mostly, which is what I ended up really learning, then realizing there was more money in computers and I could handle it, but I always liked the hardware stuff, pulling cable and such, drifted back into electrical, now I'm kinda straddling all three... I wire houses, network office buildings, design websites, record and engineer music, build amplifiers, and fix the occasional Dodge Caravan after it refuses to shut off until after it sets itself on fire.
Old 11-20-2010, 07:45 AM   #20
I=E/R
a7ecorsair's Avatar
When I was a kid, back in the middle '50s, I had an Erector Set. Lots of pieces to make thing out of and one item was and electromagnet. This set had a motor and gear box, pulleys, string, screws, and directions. The directions were just extra stuff, who would think of reading them
Now this magnet, is was metal spool with two wires hanging out and some tape wrapped around the core to hold everything together. No such thing as a TR receptacle in those day, no GFI, no AFI, no ground,no nothing except two open slots in an duplex receptacle. Poof went the magnet.....
a7ecorsair is offline   Reply With Quote
Old 11-20-2010, 07:46 AM   #21
Master Electrician
Rewards Points: 5,082
Wont do anything unless it's reverse polarity.
Try it some time.
brric is offline   Reply With Quote
Old 11-20-2010, 07:53 AM   #22
I=E/R
a7ecorsair's Avatar
Originally Posted by McSteve View Post
No, it'll be a regular sine wave, which crosses through zero 60 times a second.
120 times a second
The Following User Says Thank You to a7ecorsair For This Useful Post:
McSteve (11-20-2010)
Old 11-20-2010, 11:17 AM   #23
Wire Chewer
Rewards Points: 528
Originally Posted by brric View Post
Try it some time.
I tried it before posting. Wanted to make sure my theory was on right path. I never realized how nicely a flat head fits into a 20 amp slot.
Old 11-20-2010, 11:22 AM   #24
Wire Chewer
Rewards Points: 528
I blew MANY wall plugged transformers playing with electromagnets as a kid. 5vdc ones, 12vdc ones think I even had a 24vdc one at one point.
I recall this particular electromagnet I built using a horseshoe magnet that had pretty much lost all it's force. I decided to try an experiment to see if I can "recharge" it. So I wrap wire around both ends, plug it in. A small metal bar that was maybe a foot away immediately swiped past my hand and unto the magnet with a loud DING. Think that would have hurt if my finger was in between that. A few minutes later it started to smell funny and it was the end of that adapter.
Old 11-20-2010, 12:18 PM   #25
Mad Scientist
120 times a second
D'oh! You can tell my specialty is digital electronics; I get a little mixed up when it comes to analog waveforms...
McSteve is offline   Reply With Quote
Old 11-20-2010, 01:37 PM   #26
Master Electrician
That is NOT a loaded neutral. Try holding on to the neutral of a circuit powering flourescent lights and then touching ground.
Old 11-21-2010, 03:28 AM   #27
Semi-Pro Electro-Geek
Rewards Points: 3,620
I think you're confused. That won't do anything bad, either. After all, the other end of that wire is bonded directly to ground back at the panel. If you don't believe me and don't want to try it yourself, just measure the voltage between that neutral and ground - it'll be a couple volts at most. Inserting yourself *in series with* a loaded neutral will certainly light you up, though.
mpoulton is offline   Reply With Quote
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
