Ground Rod - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2010, 11:23 AM   #1
Rewards Points: 1,102
Ground rod
Okay, I know that for a sub a ground rod is not required, but since I plan to later convert the sub I'm putting in, I know it will be required at that time and as such I will be installing a ground rod at the sub-panel.
So I had a 1/2" diameter copper rod and a 5/8" diameter copper rod to choose from, I bought the 5/8" rod because there was a $0.50 difference and I figured even if 1/2" is adequate for 200A then it doesn't hurt to go up to 5/8"
My question is just what is the length that needs to go into the ground. This is an 8' rod. Does the whole 8' have to get pounded into the ground, or is it some shorter length with the excess being cut off?
WillK is offline   Reply With Quote
Old 12-15-2010, 11:34 AM   #2
Licensed electrician
Rewards Points: 3,660
The code requires that 8' be in direct earth contact. The top of the rod will be flush or driven below the surface. Do not cut any of the rod off and be sure to install the acorn clamp before driving the rod. If the rod mushrooms you will not get the clamp on.
For inspection you can leave the top of the rod accessible and fill the hole later.
Old 12-15-2010, 05:23 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 23,990
Until this is a main panel you should not connect the ground rod. It should be grounded to the current main panel.
Old 12-15-2010, 05:47 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,506
Ayuh,... Use an electric Demohammer, instead of a BFHammer....
The rod will Disappear before yer eyes,.... All of it....
Bondo is online now   Reply With Quote
Old 12-15-2010, 06:54 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I don't get this. What will you be "converting"?
Are you going to make this sub-panel into the main panel at some point?
Old 12-15-2010, 08:00 PM   #6
Yes. I'm working on our house, built in 1917. The second floor was entirely on knob and tube which had cellulose insulation blown in around it. The wire insulation was cracked and breaking off, the cellulose was blackenned probably from moisture due to inadequate ventilation, there were extensive birds nests in the attic. Beyond that, various splices to wires (mostly lamp cord) had been made outside junction boxes and held together with electrical tape. This wiring is removed, the kids are in a bedroom with no electricity.
The kitchen has its polarity reversed because where the outlets were spiced into knob and tube, they were spliced apparently wrong. The splice is, again, outside a junction box.
The house came with one upstairs battery smoke detector.
All of these conditions I am remedying because they are major problems that can't wait for me to have funds for a complete rewire, I am adding 11 circuits. Because there is only space for 5 in my existing 100 amp panel, I need a subpanel anyway. Since I am planning to upgrade and move the entrance, I'm using the panel I want to use later at the location I want to use later as my sub panel.
Later, I also want to run 100 amps to a new subpanel in the detatched garage. Currently, the only thing I know works in the garage is the garage door. Inoperative flourescent lighting is hanging. Anything else, I think I'd rather not try to use. The visible part of the wiring for the outlet to which the extension cord for the garage door - if you said lamp cord, you guessed correctly. I would not be suprised at all to find the garage is fed by buryed lamp cord. The garage is connected to a switch inside the house on the main circuit for the knob and tube. But this part of the project can wait since I can basicly not use electric in the garage, and digging the trench will be a bit easier to manage when the ground isn't frozen.
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
