Ground Connection In Metal Box - Electrical - DIY Chatroom Home Improvement Forum
Like Tree9Likes
  • 3 Post By Jim Port
  • 2 Post By Speedy Petey
  • 2 Post By Power-
  • 1 Post By J. V.
  • 1 Post By jbfan
Old 10-27-2016, 08:25 PM   #1
Rewards Points: 618
Ground connection in metal box
Inspector failed my rough electrical and said he wanted the grounds connected. Does this look proper in terms of length, form, etc? Should I use black tape now or after he inspects it?
Richard Pryor is offline   Reply With Quote
Old 10-27-2016, 09:02 PM   #2
listo's Avatar
Rewards Points: 107
Re: Ground connection in metal box
I've always just seen them wrapped around a screw together in the box.
Sent from my LG-H812 using Tapatalk
listo is offline   Reply With Quote
Old 10-27-2016, 09:07 PM   #3
Licensed electrician
Rewards Points: 3,740
A connection to a ground screw is also needed if the box is metal. Otherwise looks fine. YOU can also get green wire nuts that let you leave one piece long so you don't need to add a pigtail for the ground.
Skip the tape.
Richard Pryor (10-27-2016)
Old 10-28-2016, 06:12 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
No need for a separate tail to the box like you did. Just take one of the circuit grounds and wrap it around the screw and then continue on to the splice.
I'd also use green nuts for the grounds.
NO TAPE!
J. V. and Richard Pryor like this.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Richard Pryor (10-28-2016)
Old 10-28-2016, 08:36 PM   #5
Electrical Contractor
Rewards Points: 312
Jim Port and Speedy Petey make a great recommendation. No tape!!!! I hate it when I open some equipment (HVAC equip, controllers, VFD, etc....) and see people black-taping the dang wirenuts. It's hard as hell to get off, a pain the butt, and pointless.
Power- is offline   Reply With Quote
The Following User Says Thank You to Power- For This Useful Post:
Jim Port (10-28-2016)
Old 10-29-2016, 12:00 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,104
Agree with every one above;;;;\\
Especially silly to worry about tapeing a bare ground wire nut....
If made up correctly on a hot... a wire nut does not need to be taped.
MTN REMODEL LLC is offline   Reply With Quote
Old 10-30-2016, 01:34 PM   #7
J. V.'s Avatar
Rewards Points: 348
My biggest issue with tape is the goo that's left behind that you cannot get off your hands or anything else it touches.
Nasty stuff.
Power- likes this.
Old 10-30-2016, 09:48 PM   #8
Rewards Points: 618
If I have a double gang box, do I need 2 pigtails (one for each outlet)?
Old 10-30-2016, 09:57 PM   #9
jbfan's Avatar
Rewards Points: 6,428
Yes!!
Richard Pryor likes this.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
How to ground metal octogon box when mounting to 2x4? mklein49 Electrical 19 11-18-2013 07:27 PM
How to install a metal fence post DEEP into the ground? boba7523 Building & Construction 14 09-20-2011 06:34 PM
Ground connection frank otero Electrical 37 02-19-2011 09:20 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
