Green Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 10:35 AM   #1
Rewards Points: 31
green wire
I'm installing 20-amp receptacles and I'm wondering if the green grounding wire should be the same gauge (#12) as the black ("hot") and white wires.
kupalino is offline   Reply With Quote
Old 12-19-2009, 11:42 AM   #2
the Musigician
DangerMouse's Avatar
are you using romex?
DM
Old 12-19-2009, 11:45 AM   #3
Rewards Points: 308
Romex or individual wires on a 20 amp circuit must all be the same size. So yes, all three must be #12.
Old 12-19-2009, 01:01 PM   #4
Electrician
Rewards Points: 910
The ground or techniaclly the bond is usually a reduced size. I can't comment on what size it can be because it may be different in the US then in Canada.
In Canada if it was individual wires you would be permitted to use #14.
darren is offline   Reply With Quote
Old 12-19-2009, 01:12 PM   #5
Idiot Emeritus
Rewards Points: 80
With very few exceptions, in the USA, the ground must be the same size as the hots for all circuits up to 30 amps. Larger than 30 can be smaller.
Rob
micromind is offline   Reply With Quote
Low Voltage Wire Shorting Rdakota06 Electrical 3 07-22-2009 01:15 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
Another dimmer question {also wik pic} Steve S Electrical 10 11-22-2008 10:31 AM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
