Grabbing Power From Light - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 06:28 PM   #1
grabbing power from light
I have the feed running to a spot light from the main panel ,if i make the connection at the spotlight, the feed and the switch wire, can i grab power from the switch going to the spot light at the switch box to power 2 other lights in the multi box..... This is new construction.
Thank You
seekers is offline   Reply With Quote
Old 03-14-2010, 06:36 PM   #2
Electrician
Rewards Points: 910
If i understand correctly the feed is going from the panel to your light. Then you want to put in a switch loop to switch the light. If this is the case you will have to take a 3 wire between the light and the switches. The black will be your constant hot, red will be your switch leg, and then white would be the neutral.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
seekers (03-14-2010)
Old 03-14-2010, 09:49 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
If it is new construction, take all hot feeds to the switch boxes, then feed the lights.
Much cleaner install and easier to troubleshoot, and less wires in the ceiling box.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
no power to light switch diople Electrical 6 05-16-2009 01:40 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
Separating Fan and Light Switches GeauxCajuns82 Electrical 11 08-26-2008 12:03 AM
Red & Black wire from light = blown fuse leedslad Electrical 3 08-28-2006 06:54 PM
