Going From 3 Way Switch To Lutron Smart Dimmer - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 03-11-2019, 12:44 PM   #16
retired framer
Rewards Points: 4,852
Re: Going from 3 way switch to Lutron smart dimmer
Originally Posted by Boogityman View Post
Ok so then if I disconnect them won't the light not work anymore? Or that's what you would like to know? Sorry if I sound obtuse I'm just trying to wrap my head around it.
Sent from my Pixel 2 XL using Tapatalk
If the 2 wire has the power, that white connected to the three wire on the left is the neutral going to the light. there for that red and black is going to the light. So connect the black power to the switch and the black from that three wire to the other side of the switch. If not the black then the red.
That should be all you need.
Do not use flat bottom gables with scissor trusses.
Old 03-11-2019, 12:51 PM   #17
Rewards Points: 54
Perfect that makes a lot of sense. So if this is the case I can just wire the other neutral (top right wire) with the other two directly? And leave the red disconnected? I guess I would have to see if my smoke detectors still work...
Nealtw likes this.
Boogityman is offline   Reply With Quote
Old 03-11-2019, 12:58 PM   #18
retired framer
All the other wires should be dead
There is chance the extra wire going to the light is smoke detectors, that might be the black as it is connected straight to the power wire.
Old 03-11-2019, 12:59 PM   #19
Rewards Points: 54
Ok thanks will check it out tonight and let you know!
Old 03-11-2019, 04:39 PM   #20
Rewards Points: 54
Ok so updates:
- It definitely doesn't work with the black and white capped separately in the right hand box.
In the left hand box:
- tried wiring white from top right wire in with other neutrals and then:
1) putting switch between hot (bottom wire) and tagged red of top left wire: light didn't turn on, but everything else worked fine (smoke detectors and another random switch in a closet that I found out works on the same circuit). In this setup black from upper left wire was capped.
So, I tried:
2) capping tagged red, and put switch between the hot bottom wire and the black of the top left wire. As soon as I flipped the switch the breaker flipped...in this setup both red wires were capped.
Not quite sure where to go from here. Will go back and read your posts to see if I missed something but I'm at a bit of a loss here...
Old 03-11-2019, 04:54 PM   #21
Rewards Points: 588
Are you using a Lutron Caseta Pico Remote model PJ2-3BRL-WH-L01R at the second switch?
Let it Snow is offline   Reply With Quote
Old 03-11-2019, 05:08 PM   #22
Rewards Points: 54
I will eventually but haven't gotten that far yet just trying to figure out the master switch... (That will be the right hand box as visualized above).
Speaking of which, I think I've got it.
The top left wire is actually the hot. It comes from the smoke detector, which has a two wire feeding into it from the panel (the red is capped in the smoke detector junction box).
Bottom 2 wire is what continues the circuit to the closet.
So, in the left hand box, if I wire the neutrals together and put the switch between the incoming hot (black) and the tagged red, the switch (and everything else) works fine.
So right now, the red and black from the top right wire are disconnected. The neutral is still connected to the other two. But I guess I should just disconnect that? I really don't know what it is doing in there...
Anyways now to get the Lutron wired up to see if that hissing went away. But...progress! ...I think
Old 03-11-2019, 05:09 PM   #23
Rewards Points: 54
Sorry misspoke ( and can't figure out how to edit): pico remote will be in right hand box as visualized.
Old 03-11-2019, 05:17 PM   #24
Rewards Points: 54
Well, got the switch wired up and performance is exactly the same. Lol wow all this fiddling for nothing. Anyways I guess I will just deal with it and see if it bothers me when I'm not listening for it...
I guess the only question that remains is whether I should wire back things the way they were or just pull out this last neutral, cap it, and call it a day. Not sure what the best course of action is there...
Old 03-11-2019, 05:20 PM   #25
Rewards Points: 588
Are the bulbs in the fixture dimmable?
Old 03-11-2019, 05:22 PM   #26
Rewards Points: 54
Yup. Actually now that I stick my ear next to them I also hear my existing Lutron dimmers hissing a little...maybe it's normal?
Old 03-11-2019, 05:24 PM   #27
Rewards Points: 588
Are they LED, Fluorescent, or Incandescent?
Old 03-11-2019, 05:27 PM   #28
Rewards Points: 54
This new one is LED. But the existing older switches are halogen.
I am used to the bulbs humming a bit when they're incompatible but not the dimmer... Is that also a thing?
Old 03-11-2019, 05:31 PM   #29
Rewards Points: 588
The Lutron Caseta humming is usually caused by an incompatible bulb. The dimmer should not hum.
Try this Compatibilty Tool
If you still have a regular incandescent bulb, give it a try for testing purposes.
Old 03-11-2019, 05:39 PM   #30
Rewards Points: 588
The Pico is easy to program. Caseta App > Settings > Add Device > Pico > Hold bottom button for ten seconds > name it the same as the first Dimmer.
It doesn't have to be installed at the switch. It can be programmed hand held.
You'll need an adapter to mount the Pico to the switch box. model PICO-WBX-ADAPT
Help with Smart Switch? where' Ground? mbishara Electrical 6 11-28-2018 11:20 AM
GFCI after dimmer switch curiousB Electrical 16 04-08-2013 05:18 PM
lutron dimmer light switch w low voltage halogens pdxrain Electrical 4 12-30-2011 06:00 PM
Dimmer switch issues idlewatcher Electrical 0 03-07-2011 02:28 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
