GFI Outlet Help - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2010, 06:35 PM   #1
GFI Outlet Help
I bought a gfi outlet to replace an old one and there is no green grounding screw. this is a end of line instalation
dmilke is offline   Reply With Quote
Old 06-29-2010, 07:25 PM   #2
Just call me Andrew
Rewards Points: 1,032
What brand? Where did you get it?
Andrew
secutanudu is offline   Reply With Quote
Old 06-29-2010, 07:59 PM   #3
Eagle Home Depot
It has line white and hot
and load white and hot
Old 06-29-2010, 08:44 PM   #4
Possibly the hole is there & the screw fell out or was never installed during Mfg ?
Old 06-29-2010, 08:53 PM   #5
Looking closer I see a hole in the back that says "GND"
It looks like the push in type of hole.
Would this be the the place to attach the ground wire
Old 06-29-2010, 08:55 PM   #6
dSilanskas's Avatar
YES
dSilanskas is offline   Reply With Quote
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
