Gfi Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 07:19 PM   #1
gfi issue
Our gfi on our got tub is making a noise like a soft hammer drill. Do anyone know what our problem could be? The gfi is in the hot tub disconnect. We have checked for loose wires. Thank you all
brokenhammer is offline   Reply With Quote
Old 11-26-2010, 11:36 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Did you push the test button and reset button ?? the reason why you hear like soft hammer drill due the GFCI try to trip it out.
Do the GFCI device is dry or damp or wet for some reason ??
And by the way DO NOT let anyone in the hot tub until the GFCI issue is fixed first that is crictal!!!
Merci.
Marc
Old 11-27-2010, 10:27 AM   #3
How old is this gfci enclosure for the hot tub? Did u put it in by urself, if so did u get it from home depot? Ur saying its in the enclosure so I'm betting its the coil that is vibrating. Id buy a new one and install
heartlessmcfly is offline   Reply With Quote
Crinkles on full wall drywall seams. Big issue? bteudt Drywall & Plaster 9 06-30-2010 04:16 PM
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 07:29 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
