Gfi; 240 To 120 - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2010, 06:14 PM   #1
gfi; 240 to 120
I want to put a gfi outlet in outside and there is 240 power running to a pump that i want to cut into the line an add the gfi . It is going to be used for a heat tape around some water pipes. How would I wire the outlet? the ground is coming from the well pump. An I have 2 hot wires coming to the well house.
rmbell is offline   Reply With Quote
Old 09-22-2010, 07:32 PM   #2
Licensed electrician
Rewards Points: 3,662
Besides being a poor practice, you may not have a neutral you need in the existing circuit.
rmbell (09-23-2010)
Old 09-22-2010, 08:25 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
You absolutely CANNOT use this 240v line to power a 120v circuit. 99.9% sure there is no neutral present as Jim states.
Old 09-22-2010, 09:21 PM   #4
" Euro " electrician
frenchelectrican's Avatar
There are few issue it will come up very fast.
One is that you have stright 240 volt circuit sans netural there.
Second thing is where the pressure switch located again that will affect the whole thing
Third If you want to do it right you will have no choice but run new MWBC only if you have pressure switch at the pumphouse area but the pressure switch inside the house that will change the plan how to run the conductors in correct way.
Let us know what you have set up now and we can go from there.
DO NOT USE BARE CONDUCTOR FOR NETURAL !!
Merci.
Marc
Old 09-23-2010, 06:02 AM   #5
Your right there is no neutral! I think I am going to take another look at this an figure out another way to do this. Thank you for the info. RB
