GFCI On Whirlpool Tub - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2009, 01:17 PM   #1
GFCI On whirlpool tub
Hi
Can a whirlpool tub be plugged in to a regular GFCI outlet instead of using a GFCI breaker at the panel as long as the circuit is dedicated just to the tub? Is it dangerous if the circuitc is not dedicated?
Skippy
Skippymartinez is offline   Reply With Quote
Old 12-23-2009, 02:39 PM   #2
Rewards Points: 1,016
Is this a 120v (plug in to a recptacle) or 240v hardware connection?
For my 240 hardware, I got a GFCI breaker with disconnect kit from Lowes - specifically designed for connecting up a spa.
Old 12-23-2009, 06:13 PM   #3
120 volt
Old 12-23-2009, 06:35 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Receptacle or breaker. Doesn't matter, as long as it is GFI "protected".
Old 12-23-2009, 06:39 PM   #5
ok thanks guys
Old 12-23-2009, 06:54 PM   #6
I have seen 120v portable spa's with built in GFCI - sure you don't have one already? Just a thought.
Should not need to be a dedicated curcuit - but probably draws quite a bit of power so be aware of overloading possibility and poping a breaker now and then - a pain when you are all comfy in the tub.
GFCI protection outlet nearer the tub is much more convienent than a GFCI breaker in the panel - cheaper as well.
Old 12-23-2009, 09:31 PM   #7
Thanks for the info I appreciate it
Old 12-24-2009, 04:48 AM   #8
Too Short? Cut it Again!
If it were me, I would want the GFCI of any kind at the closest point near me when there was any risk I could become the new electricity ground which tends to happen in bare feet. You should invest in a dedicated circuit anyhow for the hot tub.
And if the thing has a heater are you sure you should be running it on 120V?
Old 12-24-2009, 06:31 AM   #9
Protection is protection. It does not matter where it is.
I bet you a dollar this is already required.
Chances are he does not have a choice. The circuit must be whatever the voltage of the unit is.
Old 12-24-2009, 08:54 AM   #10
My jacuzzi in the bathroom is 120v
Tub has a dedicated run for the pump - 7a
The heater has a 2nd dedicated run
Both are protected by GFCI outlets
I have seen some smaller outside hot tubs that are 120v
Old 12-24-2009, 09:54 AM   #11
Hugh?
The circuit shorts if it goes bad where it happens. If you wait for it, standing in your bare feet, near a hot tub or on a bathroom or kitchen floor, to trip the GCFI on down the line or pray the circuit breaker spots that you as a human being have become the new ground?
LOL
GCFIs were created to trip near instantly. I lost a dear friend that did not have one attached to the end of concrete saw. He was electrocuted in the time it took for the circuit breaker to pop. Had he spent $50 bucks
They are great things and belong nearest at least any place you might be working with electricity and water at the same time.
Old 12-24-2009, 12:21 PM   #12
Waiting for a GFCI to trip ? Since when
Old 12-24-2009, 12:30 PM   #13
Remodeling Contractor
sdsester .. you must not be an electrician. The entire electric circuit acts as one system. It does not matter where the GFCI protection is placed. Breakers are more expensive but also more reliable. Read on many other sites how many people have a lot of trouble with outlets tripping when they should not be. Especially if you buy them at a box store. This protected circuit monitors current leakage. When something with the circuit is faulty with a .5ma fault it trips. It does not wait for a human wet foot to trigger it.
Old 12-24-2009, 12:45 PM   #14
Hugh?
I have absolutely NO idea what it is you are trying to say here. Wait for what????
And who is Hugh?
Old 12-24-2009, 01:36 PM   #15
Chicago, IL
Michael Thomas's Avatar
Originally Posted by Skippymartinez View Post
... Is it dangerous if the circuit is not dedicated?
Check your installation instructions, all manufacture's of jetted tubs I'm aware of require a "dedicated GFCI protected separate circuit".
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
whirlpool tub gfci jeerme Electrical 8 03-04-2009 02:46 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
