GFCI Under The Sink - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 10:56 PM   #1
siggy312's Avatar
Rewards Points: 64
GFCI under the sink
I plan to location the transformers for all my low voltage under cabinet lighting under the sink. This plug will be controlled by a wall switch "near" the sink above the counter. Is this plug (under the sink) required to be on a GFCI protected curcuit ?
siggy312 is offline   Reply With Quote
Old 08-04-2010, 04:02 AM   #2
Licensed electrician
Rewards Points: 3,662
GFI protection is not required.
Old 08-04-2010, 12:19 PM   #3
siggy312's Avatar
Rewards Points: 64
I should have said... ( to be more clear )
110 will go into the wall switch, then carry on to a junction box located under the sink. The LV transformers will connect to the switched 110 inside this junction box..
I realize - this likely does not change your answer
Old 08-05-2010, 08:30 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
Same answer!
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 08-05-2010, 08:42 AM   #5
Are these lights going to be on the small appliance circuit ?
Old 08-05-2010, 11:23 AM   #6
siggy312's Avatar
Rewards Points: 64
"small appliance circuit" ?
a separate 15 amp circuit (14-2) will feed two transformers.
one smaller transformer for 3 x 12-volt xeon lights
one larger transformer for 6 x 12-volt xeon lights
Old 08-05-2010, 11:27 AM   #7
Where are you located ?
In the US 2 SABC's are required
Hard wired lights can't be connected to them
...but plug in lights can
If this circuit is an added circuit, not a problem
Old 08-05-2010, 11:43 AM   #8
siggy312's Avatar
Rewards Points: 64
Canada ( province od Saskatchewan)
This is a kitchen reno (on an old house)...
plan is to run one 15amp circuit. 110 to a wall switch, then down to a
60 cubic inch box under the sink, where the transformers would be hardwired to the 14/2. My math tells me that nine 20 watt / 12 volt lights will give me a load of 15 amps.
Old 08-05-2010, 11:47 AM   #9
(9) 20w lights = 180w = 1.5a
Can't help you on Canada codes...sorry
Question about GFCI behind future kitchen sink ChrisDIY Electrical 5 02-18-2010 09:02 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
I need GFCI, right Ultrarunner2017 Electrical 6 01-16-2009 07:53 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
