GFCI For Sub-Panel - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By rjniles
Old 10-31-2016, 04:39 AM   #1
Rewards Points: 6
GFCI for Sub-Panel
Installing a sub-panel within my home. Some of the circuits of the sub-panel will have GFCI breakers installed for them in the sub-panel. Must the breaker within my main panel which serves the sub-panel therefore be a GFCI breaker or can I keep the standard trip breaker serving the sub-panel? Thanks.
snyderk523 is offline   Reply With Quote
Old 10-31-2016, 05:03 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 386
Re: GFCI for Sub-Panel
The breaker feeding the sub is a standard breaker.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 10-31-2016, 08:41 AM   #3
Rewards Points: 18,506
Why are you using GFI breakers, and not a GFI outlet instead on the circuit that needs protecting?
Far more expensive for breakers.
Old 10-31-2016, 08:51 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 386
There are reasons to use GFCI breakers instead of receptacles;
Accessibility, a GFCI must be accessible with out moving equipment and must not be so high to be unreachable.
I have 2 15 amp circuits for my spa tub, they are located behind the tub access panel. I used GFCI breakers.
Size of the electrical box. Old small metal electrical boxes can be difficult to fit a GFCI receptacle.
MTN REMODEL LLC likes this.
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Jim Port (10-31-2016), Oso954 (11-01-2016)
Old 10-31-2016, 07:50 PM   #5
Rewards Points: 6
As to why I'm using GFCI breakers, the branch circuits are for pool equipment. One of which must include a 20 amp twist lock outdoor receptacle - of which I am unable to find one of the GFCI variety. So, I'm putting the protection in the sub-panel. Another is a pool light, which I do not yet have the transformer so I am working ahead in case the transformer doesn't have any GFCI protection and just doing it at the sub-panel.
So, does everyone agree I don't need the GFCI breaker in my main to supply my sub?
New meter panel for 1955 house. Use old breaker panel as sub panel. mitchedo Electrical 5 10-11-2015 10:24 AM
panel upgrade options for new HVAC installation buyabook Electrical 12 09-14-2015 10:39 PM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
