GFCI Problems - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 10:13 AM   #16
Rewards Points: 5,348
Originally Posted by trudyjk View Post
unfortunatly the cord isn't long enough.
You would lift the heater out of the pool and bring the unit inside to plug it in.
Ron
Old 01-09-2010, 12:21 PM   #17
Both heaters are new and made for ponds.
trudyjk is offline   Reply With Quote
Old 01-09-2010, 12:29 PM   #18
Both heaters are now frozen in the pond. My aereator is still running which brings oxygen to the fish and keeps water under the ice from freezing, I just don't know how long it will stay that way. The two GFCI's are on different circut breakers on my panel. I don't know if there is a surge when the heater is plugged in that is setting off the GFCI or if I need to repace them or add a more powerful breaker. None of this I think I can do myself so I probably will be calling an electrician Monday morning unless there are any more ideas out there. Thanks Much, Trudy
Old 01-09-2010, 05:54 PM   #19
Originally Posted by codeone View Post
It was about an 1/8" thick.
Could be they encapsulated it to prevent competitors from reverse engineering their product.
Old 01-09-2010, 07:34 PM   #20
Inspector/Instructor
codeone's Avatar
All new GFCI receptacles required for the 2008 NEC are required to be Weather Resistant, They are marked with a WR on the face they are also Tamper Resistant for the new 2008 NEC requirements also.
codeone is offline   Reply With Quote
Old 01-09-2010, 07:53 PM   #21
My understanding is the WR is only required in wet or damp areas (406.8) ?
Old 01-09-2010, 08:04 PM   #22
codeone's Avatar
Thanks Dave left that out , was thinking about the original posters situation.
Old 01-09-2010, 08:05 PM   #23
Ah...Pond...yes that would qualify
I'm getting my threads messed up
Old 01-09-2010, 08:11 PM   #24
Exclamation
Originally Posted by beenthere View Post
Please do not make duplicate threads across the forums. I removed your other one.
Thank you.
I had a hunch (that) she is disingenuous about the problem she is posting. But as a general rule, any object (in this case a heater) that is placed in water, the GFCI will pickup on it and trip out!???!!!
spark plug is offline   Reply With Quote
Old 01-09-2010, 08:15 PM   #25
codeone's Avatar
Also all outdoor areas .
Old 01-10-2010, 03:14 PM   #26
Disingenuous? Sorry I don't understand everything that you all are saying. I came to this form for information. I would like to find out the problem with my GCFI. I think alot, not all, of you just like to blow your own horns and I feel some of you are the disingenous ones.
Old 01-10-2010, 03:21 PM   #27
I've had multiple water heaters in my saltwater aquariums for the past 10+ years & they have never tripped the GFCI
Also several different pumps that run 24x7
Some people even have lights in their ponds & aquariums - underwater
So you are saying no-one has a pool light on a GFCI ?
I'm more then a little puzzled by your statement
Are you using in-use wet covers on the outlets ?
Old 01-10-2010, 03:53 PM   #28
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
how heavy is the extension cord youre using?
plummen is offline   Reply With Quote
Old 01-10-2010, 05:42 PM   #29
Super Moderator
joed's Avatar
Rewards Points: 23,984
You said the aerator does not trip the GFCI. That leads me to believe the problem is with the heater or the cord you are using to plug it in. You also tried the same setup in another GFCI and it tripped. Same conclusion to me. There is a problem with heater or the cord.
I am assume it is the GFCI feature that is tripping and not the over current protection. That could be a whole different issue. What is the voltage and wattage ratings of the heater? What is the breaker size of the circuit you are plugging into.
Old 01-10-2010, 06:00 PM   #30
Thumbs up
Scuba Dave (Poster #27) (I didn't reply with the (ample) Quote. Because there is no use in my repeating the picture.) OK. Essentially, what I was saying is that if (as the poster stated) the heaters are sitting in the water (albeit partially), there's a good chance of them picking up conductivity (leakage current) thus improving the chances of a trip out! As for the pool lights. They are wired in rigid Conduit and sealed at the joints. Thus are close to 100% water proof. And in cases where there is moisture seeping in they DO trip out, too. I have had plenty of service calls for GFCI trip out's where the pool light circuit was seeping in (very) small amounts of water.! This is an addendum to the post! As far as pumps are concerned. No metal parts that trace back to the frame are dipped in the pool. It's mostly plastic. Therefore, the chances of conductivity are remote.
Last edited by spark plug; 01-10-2010 at 06:14 PM. Reason: Added to the (original) post for clarification
GFCI Problems richardcaffrey Electrical 4 07-13-2009 05:30 PM
Problems with GFCI Outlet FieldersChoice Electrical 11 01-04-2009 01:53 PM
Problems with GFCI! trevelyan Electrical 13 05-10-2008 06:25 PM
GFCI Problems deadeyeusa Electrical 21 12-09-2007 11:28 PM
GFCI breaker problems bwoo Electrical 5 12-09-2006 02:53 PM
