GFCI Outlet - 1/2 Grounded? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree7Likes
  • 3 Post By joed
  • 4 Post By rjniles
Old 12-04-2019, 12:52 PM   #1
Rewards Points: 36
GFCI outlet - 1/2 grounded?
Ran across an outlet that I want to replace.
It's a GFCI, but top appears to be grounded, bottom is not.
Is this common? Any good reason for this?
I'm assuming I could replace it with a standard GFCI receptacle. Yes? No?
Thanks in advance!
GreyGoat is offline   Reply With Quote
Old 12-04-2019, 12:57 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,966
Re: GFCI outlet - 1/2 grounded?
Yes replace a modern GFCI.
Are you sure it is not grounded on the bottom? I have never a receptacle that was only half grounded. The plug is probably covering it.
Old 12-07-2019, 01:05 PM   #3
Rewards Points: 164
While I don't recommend having an ungrounded outlet, a ground is not required for proper GFCI operation. A GFCI outlet will still function correctly in a 2-wire system...however, if the ground is missing, the "test" button will not work as it shunts enough current into the ground to trip the circuit.
If you have an ohm meter, measure the two ground connections on the outlet...I'd be surprised if they weren't internally connected.
The second ground would be used for another outlet downstream...
zhawkeye is offline   Reply With Quote
Old 12-07-2019, 02:31 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 382
The test button on a GFCI will work even if the receptacle is not grounded. The GFCI test button on a plug in 3 pin tester will not.
jbfan, joed, Yodaman and 1 others like this.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 12-08-2019, 05:08 AM   #5
Rewards Points: 636
RJ that is something some people don't know. I had an inspector once from HUD telling me that a GFCI must be grounded and that it should always trip with the plug-in tester. I battled with him and finally won. It was an older house with un-grounded circuits so I put in GFCIs. Passed all the other times with other inspectors at other properties.
Sorry, did not mean to hyjack thread
afjes2015 is offline   Reply With Quote
