GFCI LOAD Terminals - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 06:05 PM   #1
Rewards Points: 14
GFCI LOAD terminals
When a GFCI trips, does it continue to supply power to the LOAD terminals or is power cut off as well?
I'm installing a GFCI in a small bathroom. I would like to use the LOAD terminals to feed a switch that will control a wall sconce. If the GFCI trips, will the wall sconce light go out?
worthspending is offline   Reply With Quote
Old 09-12-2011, 06:08 PM   #2
Master Electrician
Rewards Points: 5,374
When a GFCI trips the load terminals are dead. The line terminals behind the switch will remain live while the power is still dead to anything plugged into the receptacle.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
worthspending (09-12-2011)
Old 09-12-2011, 06:11 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,904
If you want the lights to remain on then do NOT use the LOAD terminals. Pigtail the feed wire to the GFCI to supply the switch as well.
The Following User Says Thank You to joed For This Useful Post:
Old 09-12-2011, 06:24 PM   #4
Rewards Points: 14
Thanks everyone!! That is all I needed to know.
50 Amp GFCI tripping casnart Electrical 26 08-17-2011 04:12 PM
GFCI grounding; and inside double gang box? Wildswalle Electrical 5 05-29-2011 01:25 PM
GFCI Stumper ksqrdks Electrical 2 04-03-2010 06:24 AM
GFCI with 12/2 wire Safety Question Coors Electrical 8 03-09-2010 04:53 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
