GFCI Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 03:25 PM   #1
GFCI Issues
Having an issue attempting to replace a regular receptacle with a GFCI type. On a 20-Amp circuit running into the kitchen I have 2 receptacles and a single-pole switch which controls one of the receptacles (the garbage disposal is plugged into the switch-controlled receptacle).
I am attempting to replace the non-switch controlled receptacle with a GFCI. I made sure I had a 20-Amp GFCI. After installing the receptacle and restoring power to the circuit, (switch turned OFF) the GFCI functioned normally. When I flipped the switch to the other receptacle (powering the garbage disposal) the GFCI tripped. I swapped the GFCI back out with a standard receptacle and the circuit functions as normal.
I'm new to DYI electrical work, so I don't know why the GFCI would trip when the disposal was powered on. Does anyone have any ideas?
SilentPete is offline   Reply With Quote
Old 10-04-2010, 03:26 PM   #2
Licensed electrician
Rewards Points: 3,662
Is the disposal on a dedicated circuit or the same circuit as the receptacles?
Old 10-04-2010, 03:29 PM   #3
Same circuit. The disposal is plugged into the switch controlled receptacle.
Old 10-04-2010, 03:48 PM   #4
assuming the disposal switched outlet is fed from the load terminals of the gfi; if the disposal is unplugged and you turn on the switch does the gfi trip?
if no, I would suspect a ground fault in the disposal (tiny, not a dead short)
CuHead is offline   Reply With Quote
Old 10-04-2010, 03:55 PM   #5
Electrical Contractor
kbsparky's Avatar
IT sounds like you wired the feed for the disposal switch "downstream" from the GFI unit. The neutral conductors may be separately wire-nutted thus creating an imbalance when attempting to operate the disposal unit.
Be sure to ONLY use the "line" terminals on the GFI receptacle when connecting it into the middle of a circuit like this.
That should solve your dilemma.
-KB
Old 10-07-2010, 05:01 PM   #6
Are garbage disposal receptacles required to be gfi protected since they within six feet of a sink?
ader220 is offline   Reply With Quote
Old 10-07-2010, 05:09 PM   #7
jbfan's Avatar
Rewards Points: 980
No, as they are under the sink.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
GFCI issues.. dsean Electrical 10 06-13-2010 06:03 AM
Leviton 8599 GFCI wiring issues Ultrarunner2017 Electrical 4 02-06-2009 08:53 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 02:41 PM
