GFCI Face Plate - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2010, 08:49 PM   #1
GFCI face plate
I'm new here and wanted to say Hello. I do have a question about labeling gfci face plate with the paper gfci sticker. It doesnt last long
and falls off. Inspectors want it on and write us up if it isnt. Is there a
more permenate way that looks good and stands up to time?
markos55 is offline   Reply With Quote
Old 07-07-2010, 09:16 PM   #2
an engraved cover
voltz is offline   Reply With Quote
The Following User Says Thank You to voltz For This Useful Post:
markos55 (07-08-2010)
Old 07-07-2010, 09:32 PM   #3
Rewards Points: 6,652
When you know that the inspector is coming, slap the sticker up. Then when he/she leaves, take the sticker off. I have never seen a plate that the sticker is on ever, or very long, regardless if commercial or residential.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 07-07-2010, 09:46 PM   #4
I've never seen one on a faceplate either (other houses - new construction)
I have put them on outlets in my basement, pool cabana & outside outlets that are protected by GFCI
I do not have any in my kitchen, sunroom or anywhere else
Where are you located ?
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 07-07-2010, 10:07 PM   #5
I=E/R
a7ecorsair's Avatar
I opened up my brand new three pack of GFCIs and sure enough there is a sticker pack with stickers in three different languages. I've never seen a GFCI with these stickers. Is it a code requirement to have these on? Since everything in the US is printed in at least three languages, I suppose I will have to put three stickers on just to be safe
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Old 07-08-2010, 12:22 AM   #6
" Euro " electrician
frenchelectrican's Avatar
There one trick I done from time to time to keep the RCD { GFCI } sticker stay perament is .,, ask your lady or wife to use the clear fingernail polish that will do the trick.
And give them a flower or something to keep them happy otherwise go in some store they will have clear fingernail polish for couple Euros { few dollars }
Even clearcoat automovite paint will do the samething in touch up bottle.
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 07-08-2010, 04:41 PM   #7
I live in Austin Texas and work at a School for the cognitively Challenged. ThankYou for the information.
Old 07-08-2010, 09:36 PM   #8
I=E/R
a7ecorsair's Avatar
So this inspector is not the electrical inspector but someone like a building safety inspector. Is this correct?
Old 07-08-2010, 09:46 PM   #9
Do the students know what a GFCI is ?
I think this info may change things a little
Old 07-09-2010, 07:30 PM   #10
Yes that is correct it is a safety inspector.
Old 07-09-2010, 07:34 PM   #11
No I dont think they know, its just something that is required.
Old 07-09-2010, 08:55 PM   #12
In that case, you may be able to find a local company that does engraving, and see if they will engrave the wall plates, and then use enamel paint such as the color red to highlight the wording 'GCFI'. Found this company online that sells the Decora plates with GCFI engraved http://www.kyledesigns.com/product/S...-Location.html
Old 07-10-2010, 06:29 AM   #13
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
A Brother P-Touch labeler would work fine as well.
Old 07-10-2010, 07:20 AM   #14
Rewards Points: 1,192
Merci.
Marc
"That melted my cover plate!"
bobelectric is offline   Reply With Quote
Old 07-11-2010, 01:06 AM   #15
Well.,
I should mention it depending on which type of switch plate cover you are using if thermoplastque you should be ok but other type of plastique try with one cover first to see how it react to it.
Metal plates are not a issue at all.
Merci.
Marc
Router Mortising Kit for Door Face Plate GeauxCajuns82 Carpentry 9 02-15-2011 11:08 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 09:31 AM
Metal Plate for Stud's Face to Protect Cable Lovegasoline Electrical 17 12-04-2009 06:40 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
Getting shocked by face plate screws vogtage83 Electrical 21 12-04-2007 11:55 AM
