GFCI Breaker Won't Reset - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2010, 05:55 PM   #1
Just call me Andrew
Rewards Points: 1,032
GFCI Breaker won't reset
Friend's house...older house with newer 200A service. I think it's a Westinghouse panel.
There is one circuit that feeds outlets all over the place...including the kitchen counter and the living room. Against code, I know, but that's how it was when he moved in.
A GFCI breaker is on that circuit. One day out of nowhere, it tripped. Now it won't reset. He was just using the computer, and it shut off, turns out that was why. He wasn't connecting or disconnecting anything at the time. Tried turning off then back on, still won't stay on.
Is this likely a bad breaker or something else? Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 09-11-2010, 06:05 PM   #2
I=E/R
a7ecorsair's Avatar
Do you know if there is any outlets or other devices connected to the load terminals? What you could do if there is a connection on the load is disconnect it and see what the results are. Don't forget to turn off the breaker
If there is nothing on the load side and nothing plugged into the GFCI then it could very well be a bad GFCI..
a7ecorsair is offline   Reply With Quote
Old 09-11-2010, 06:09 PM   #3
Just call me Andrew
It's a GFCI breaker...not an outlet....so it's all on the Load side....
Andrew
Old 09-11-2010, 06:27 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
first thing would be to unplug everything from the circuit and try to reset again.
It's been awhile since I played with GFCI breakers so not positive this will work but I would then remove the circuit conductors from the breaker and try to reset. If the breaker resets, I would suggest there is something wrong with the circuit.
If there is another GFCI breaker in the panel, try flipping the circuit conductors to that breaker. If that breaker then trips, there is something wrong in the circuit. If it doesn't, then I would suspect the breaker.
Old 09-11-2010, 09:30 PM   #5
Electrical Contractor
kbsparky's Avatar
Using a computer, eh? Betcha there is a surge power strip plugged into that circuit.
As nap said, unplug everything first and see if that breaker resets.
-KB
Old 09-11-2010, 11:14 PM   #6
Just call me Andrew
Thanks everyone.
Andrew
Old 09-12-2010, 02:41 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Once you unplug everything on that circuit and try to reset the RCD { GFCI } if reset then plug in one at the time until kick out with bad item.
If none happend then try the light switch as well.
But if tripped after everything is unplugged Nap have one good way just unhook the hot conductor from the breaker and leave the netural conductor alone and hit the breaker to turn on to see if that stay in place if not then the breaker is done for it.
If still stay in place then you may have issue with the circuit and also check the outdoor recetpales as well if you have them.
Merci.
Marc
Can I replace a breaker w/ gfci myself secutanudu Electrical 12 07-28-2009 11:41 AM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
How to connect switch to GFCI breaker? firemanter Electrical 3 10-28-2008 07:46 PM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 05:48 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
