GFCI From Bath #1 To Bath #2 - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2015, 07:46 AM   #1
Rewards Points: 121
GFCI from Bath #1 to Bath #2
Can you use the load side of GFCI in Bath #1 to power a standard outlet in Bath #2.
Bathrooms are back to back on the same floor.
It this still code? I know at my mother in law's house the bathrooms are wired like this.
Code reference if possible. Thanks!
icepal1999 is offline   Reply With Quote
Old 06-01-2015, 07:58 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,790
I don't have the code #, but the general wording is" all bath receptacle can be on one circuit, or one circuit can feed everything in one bath.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
icepal1999 (06-01-2015)
Old 06-01-2015, 09:47 AM   #3
Rewards Points: 121
Thanks for the info jbfan, but I need the code reference. I've seen that code, but is this something that is allowed by local inspectors? or not.
Was code in the past but not now?
Thanks to all.
Old 06-01-2015, 09:50 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,946
If the circuit only contains receptacles in bathrooms then you can do it. If you add anything like lights or fans to the circuit then must stay within the one bathroom.
The Following User Says Thank You to joed For This Useful Post:
Old 06-01-2015, 10:02 AM   #5
Rewards Points: 121
Great joe - that's what I wanted to know.
I figure if the GFCI in Bath #1 went to lights, etc. on the load side - than no you couldn't go to Bath #2.
Still code reference? All I have 210.11 (c) (3) exception
Old 06-02-2015, 10:09 AM   #6
Rewards Points: 2,084
Thanks to all.
NEC 2014 check articles 210.11(C)(3) and 210.23(A). Be sure to read the exceptions.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 06-02-2015, 10:34 AM   #7
Rewards Points: 600
Remember that the NEC lists restrictions and requirements. It doesn't give a list of all things allowed.
jreagan is online now   Reply With Quote
Old 06-02-2015, 10:56 AM   #8
Licensed electrician
Rewards Points: 3,840
If it is not specifically banned by the NEC it is allowed.
jbfan (06-02-2015)
Weird problem with GFCI breaker tripping from different circuit in a different panel. mgh-pa Electrical 39 08-05-2014 03:22 PM
Air conditioner GFCI broken fdmillion Electrical 9 07-24-2014 10:30 PM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
