Generator In Shed Near Gas - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By dmxtothemax
Old 10-09-2019, 02:08 PM   #1
Rewards Points: 8
Generator in Shed Near gas
I have a 10x8 metal shed that is 40ft from the house. In one corner of the shed I built a metal exhaust that attached to my generator exhaust. Next to the generator is a 24x24 grated intake I installed. Above the generator at the top, I have 2 12x12 exhaust fans that are powered by the generator. I have tested this under load for an hour on a nice hot sunny day and the inside temperature of the shed never rose more than 3-5 degrees above the outside temp. So right around 95 degrees.
My only concern is that the only place for me to store gas is in this shed as well, on the opposite side of the generator. I store anywhere from 20-40 gallons in 5 gallon approved cans.
Since the shed isn't next to the house, there is 2000 CFM of air of ventilation, and temp doesn't go above 95, is there a huge risk in running the generator in the same shed as the fuel? I know common sense would say don't do it as the vapors the cans release are flammable but if these are removed before the generator is started, I don't see how they could build up with 2000 CFM of airflow.
Mr Skunks is offline   Reply With Quote
Old 10-09-2019, 03:42 PM   #2
Oso954's Avatar
Rewards Points: 2,174
Re: Generator in Shed Near gas
Many fire codes limit you to 25 gallons in a residential area. You can check your local refs with your code enforcement people or the Fire Marshall.
Oso954 is online now   Reply With Quote
Old 10-09-2019, 03:45 PM   #3
Rewards Points: 8
Assuming I only store 25, my question is still the same. Am I being very risky by running the generator near these gas cans.
What are the real risks? I would appreciated detailed answers rather than "Do that if you want to DIE "
Old 10-09-2019, 04:28 PM   #4
dmxtothemax's Avatar
Rewards Points: 7,520
You have nothing to worry about !
Chances are so small you need a microscope
Kevin_Essiambre and Nealtw like this.
dmxtothemax is offline   Reply With Quote
Old 10-09-2019, 04:45 PM   #5
Super Moderator
joed's Avatar
Rewards Points: 24,026
The generator is not a source of ignition, no open flame or spark. I would not be concerned.
Old 10-10-2019, 09:28 AM   #6
Rewards Points: 8
Sarcastic? Lol
Old 10-10-2019, 07:01 PM   #7
Rewards Points: 498
Why not ask your local Fire Chief ?
Let it Snow is offline   Reply With Quote
