Generator Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2019, 03:40 PM   #1
Rewards Points: 2
Generator problem
I run a mobile dog grooming trailer and my generator was running good until yesterday. Now it only supplies half the power it normally does. I hook the trailer to the house and everything works. When the trailer is on the generator only half the main breaker is getting power how do I fix it?
Barkingham mobi is offline   Reply With Quote
Old 02-23-2019, 06:08 PM   #2
Rewards Points: 680
Re: Generator problem
Try resetting the output breaker on the generator.
LawnGuyLandSparky is offline   Reply With Quote
Old 02-23-2019, 06:15 PM   #3
dmxtothemax's Avatar
Rewards Points: 7,820
Sounds like you have lost one leg or hot.
Loose splice, blown fuse,
Faulty breaker, faulty outlet.
Do you have any test equipment ?
Multi meter or non contact tester ?
dmxtothemax is online now   Reply With Quote
Old 02-23-2019, 07:58 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 2,932
Some generators have switches for 120 versus 240 volts. Check that as well. Does your generator have a voltage meter? If so what voltage does it indicate?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 02-23-2019, 08:09 PM   #5
hkstroud's Avatar
Rewards Points: 6,684
I had the same type of problem with a small portable generator. Only one 120 outlet would work and no 240V. Loaned to a friend who was out of power after a hurricane. He had a mutual friend who was an electrician look at it but he didn't know what was wrong.
I finally took it apart to find a broken wire. Don't know how or why that happened but it sounds like you have a similar problem. You need someone with enough mechanical ability to disassemble and look for what is wrong.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
